Integra LS block with a GSR head will it work
Old Jun 26, 2002 | 07:26 AM
Hollywood's Avatar
Default Integra LS block with a GSR head will it work
What would I have to do to make a GSR head work properly on a LS block?
Is it true that the car would be keepin' up with Type-R's because of better compression?
You know the cap that the V-tech has on it? If that cap is smaller, is that better because it builds up more preasure?
Old Jun 26, 2002 | 07:37 AM
ragejed's Avatar
Default Re: Integra LS block with a GSR head will it work (Hollywood)
Search for something called LS/VTEC
and its not spelt V-TECH
Old Jun 26, 2002 | 08:15 AM
yisoulja's Avatar
It will work with some minor machining. Im doing the same thing and yes you would be able to walk on ITRs........If you do everything right. And no the compression wouldnt be better unless you got new pitsons.
Old Jun 26, 2002 | 08:46 AM
rubens's Avatar
for LS/VTEC to work, you're going to first need to find a B18C (GS-R) or B16A (Si) head. Along with that you're going to need someone who knows what they're talking about (mechanic wise) and a good tuner. I'd reccomend reading a lot about LS/VTEC..and consider your other options... like turbo..
Old Jun 26, 2002 | 09:50 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
what??
Old Jun 26, 2002 | 11:09 AM
b18bvtec4drteg's Avatar
Default Re: Integra LS block with a GSR head will it work (dLo GSR)
LMAO Vtech cap makes lots of pressure??? hahaahhahahhahahhahaa X1000000000000 The funniest crap Ive ever heard....
Old Jun 26, 2002 | 11:36 AM
bruthaboost's Avatar
Don't do this unless you want an all motor monster. In order for lsvtec to be built well and make power worth the money your'e spending it's an all or nothing endeavor (sp?)
Old Jun 26, 2002 | 11:47 AM
jdmhatch's Avatar
what??
lol
shadowdawn's Avatar
Default Re: Integra LS block with a GSR head will it work (bruthaboost)
I dunno where roselle nj is, but if its up north somewheres you should meet up with me and take a ride in a turbo-ed teg first to rule out that option granted I'm automatic but you will still feel what a turbo is all about.. just remember since your probably stick you will just be faster than me
Old Jun 27, 2002 | 01:26 PM
g's integ's Avatar
Default Re: Integra LS block with a GSR head will it work (ragejed)
Easy on the newbie, where not here to flame on him...
Can we all just get along...
Check out this links:
http://crvtec.com/
http://www.c-speedracing.com/howto/lsvtec/lsvtec.html
[Modified by g'sinteg, 2:32 PM 6/27/2002]
Old Jun 27, 2002 | 02:18 PM
alexboy's Avatar
FALSE
the ls/vtecs around here(CT) run great with minor work done at he fraction of the cost of a gsr motor... I could have built a b20vtec with performance rods and pistons for the same price as a normal gsr swap and i will guarantee the b20 will murder a gsr.. but back to ls vtec find a shop that has done it before zand you should be fine
[Modified by alexboy, 6:19 PM 6/27/2002]
Old Jun 28, 2002 | 07:25 PM
JDM_ITR's Avatar
my friend is running this setup (gsr head/ls block) and ITR pistons. low cost set up, and hes murdering ITRs.....he has it in a 91 2dr civic.
Old Jun 28, 2002 | 08:23 PM
baonest's Avatar
Default Re: Integra LS block with a GSR head will it work (JDM_ITR)
there we go again. "VTECH"
chiefrocka
May 30, 2009 07:33 PM
99_turboteg
Feb 1, 2008 03:56 PM
tfalconier
Sep 28, 2004 09:08 PM
mxler8
Jul 27, 2004 07:57 PM
wildstallion
Nov 28, 2002 12:56 PM
