No A/C.. HELP!!
Old Jun 26, 2002 | 06:51 AM
PurpleGsR00's Avatar
Default No A/C.. HELP!!
its soo damn hot today.. and im driving with no A/C i guess i need some freeon.. or however you spell it.. i have a 2000 gsr.. is it common that i would need to fill up with freeon this early.. and where can i go to get it done.. and how much would i expect to spend?
Old Jun 26, 2002 | 08:05 AM
JL 74's Avatar
Default Re: No A/C.. HELP!! (PurpleGsR00)
A bit too soon there for a refrigerant recharge. Make sure it gets tested for leaks. Expect to pay over a hundred.
Old Jun 26, 2002 | 08:11 AM
AcuraRacer112's Avatar
Default Re: No A/C.. HELP!! (jl74)
<---rides around in 100 plus degree heat, with fleece on
But as for your problem that sounds odd, I would get checked out. The AC should not need recharging, i have a 00 GS-R when I do drive it, it still blows cold air If I ever do use the AC, for girls and mom So I would get it checked out, it should still be under warrenty, at the dealership. Good luck and how hot is it in the NY?
Old Jun 26, 2002 | 08:23 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
should still have a warranty, take it to the dealer.
Old Jun 26, 2002 | 04:28 PM
Default Re: No A/C.. HELP!! (PatrickGSR94)
yeah i just made an appointment for july 8th.. i guess im gonna have to deal with it for 2 more weeks
Old Jun 26, 2002 | 04:43 PM
Just_LS's Avatar
Check you a/c line below you bumper, mine got puntured (by a rock, I guess) and cost about $150 to get a new line and refill the freon.
Old Jun 26, 2002 | 05:54 PM
Default Re: No A/C.. HELP!! (Just_LS)
what exactly does the line look like?? and if it isnt punctured what could some other problems be?
Old Jun 27, 2002 | 11:03 AM
Just_LS's Avatar
Under your bumper on the driver's side there's a tube/line in front of the radiator, it should be black, if you see any area is not, it's probably puntured there. If this is the case, all you need is a new line and refill freon. HTH
Old Jun 27, 2002 | 11:19 AM
ragejed's Avatar
mine is a 98 with 43k on it. think i will need to recharge mine? its really not cold
i read the hayes manual that ican just buy a recharge kit
Old Jun 27, 2002 | 11:35 AM
96_GSR's Avatar
Default Re: No A/C.. HELP!! (ragejed)
I got a 96 with 83,000 and it's never been recharged, and it's still nice and cold..leaks has to be the problem.
Old Jun 27, 2002 | 12:10 PM
bamaTeg's Avatar
New User
Default Re: No A/C.. HELP!! (96_GSR)
had my 'suction' line replaced due to a leak and it cost me $150 including labor and freon. The part itself was $100 for the suction line.
Old Jun 27, 2002 | 02:00 PM
Cramerox's Avatar
AC LINES
picture provided by RATEDR
[Modified by Cramerox, 11:00 PM 6/27/2002]
itgrowsind
Aug 20, 2011 09:09 AM
JDMDC295
Aug 18, 2007 07:49 PM
SlammedDC2
Jul 4, 2006 09:13 PM
LatinSiRacer00
May 14, 2004 02:05 PM
AutoXsi2000
Jun 7, 2002 04:35 AM
