code 17 vss(vehicle speed sensor)?
Old Dec 3, 2007 | 11:53 AM
slowassBubble's Avatar
Default code 17 vss(vehicle speed sensor)?
alright i just got my clutch changed yesterday on my 1990 civic rt4wd wagon...anyways the job wasnt done by because its too cold outside and i dont have garage. i got a code 17 vss, and my speed sensor isnt working, i would take it back to the mechanic but i think i can fix it quicker than he can, its probably unpluged or sumthing. anyways my question is were is it located, is it electrical? what does it look like...thanks guys
Old Dec 3, 2007 | 12:05 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: code 17 vss(vehicle speed sensor)? (slowassBubble)
Look here toward the bottom:
https://honda-tech.com/zerothread?id=1325930
Old Dec 3, 2007 | 02:34 PM
Default Re: code 17 vss(vehicle speed sensor)? (88DXCRX)
ok i saw the tread, but if my sppeedo is a cable then how does my ecu know my speedo isnt workin?
Old Dec 3, 2007 | 03:33 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassBubble &raquo;</TD></TR><TR><TD CLASS="quote">ok i saw the tread, but if my sppeedo is a cable then how does my ecu know my speedo isnt workin?</TD></TR></TABLE>
It just does.
Old Dec 3, 2007 | 03:47 PM
88DXCRX's Avatar
Default Re: code 17 vss(vehicle speed sensor)? (gibsanez)
Inside the speedometer is a speed sensor
which sends a pulse to to ecu..
Old Dec 3, 2007 | 06:06 PM
Jonny Rocket's Avatar
Dont mean to jack your thread but if the speedometer cable is unpluged then the governor will never kick on, correct??
Old Dec 4, 2007 | 02:49 AM
408wdy's Avatar
Default Re: code 17 vss(vehicle speed sensor)? (Jonny Rocket)
the car will run like ****.. i had a cel 17 code and i got horrible mpg
Old Dec 4, 2007 | 05:14 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Dont mean to jack your thread but if the speedometer cable is unpluged then the governor will never kick on, correct??</TD></TR></TABLE>
Our cars do not have speed governors?
And no, it won't remove your rpm fuel cup that's programmed into the ecu.
Old Dec 4, 2007 | 06:34 AM
b16a1eg6's Avatar
Default Re: code 17 vss(vehicle speed sensor)? (ludesrv)
when I put my B16 in with the stock PR3 ecu it had a speed cut of around 110mph.
Old Dec 4, 2007 | 06:53 AM
VtecSyndrome's Avatar
Default Re: code 17 vss(vehicle speed sensor)? (b16a1eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a1eg6 &raquo;</TD></TR><TR><TD CLASS="quote">when I put my B16 in with the stock PR3 ecu it had a speed cut of around 110mph.</TD></TR></TABLE>
The JDM ECUs have the fuel cut programmed in but I know the USDM ECUs don't have it. Not to sure about the UKDM or others, just know about the JDM ones
JDM OBD 0 ECUs cut off around 110-112ish
JDM OBD 1 ECUs cut off around 120ish
Old Dec 7, 2007 | 03:09 PM
Default Re: code 17 vss(vehicle speed sensor)? (VtecSyndrome)
Fuel cut huh? how does the ecu know your in 5 gear?? and would it have the fuel cut at any gear??? mines a jdm sohc zc ecu OBD-0 and I can only go up to 120 but I can go further with no problem if it didnt cut off there.
Also my friend has a GSR swapped crx and he was able to do 140 without the cut and his speedo cable is off.
Old Dec 8, 2007 | 07:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Fuel cut huh? how does the ecu know your in 5 gear?? and would it have the fuel cut at any gear??? mines a jdm sohc zc ecu OBD-0 and I can only go up to 120 but I can go further with no problem if it didnt cut off there.
Also my friend has a GSR swapped crx and he was able to do 140 without the cut and his speedo cable is off.</TD></TR></TABLE>
So tell me, can you really go 120pmh in any other gear but 5th?? so that part is irrelavant and likely your speedo is off if it says 120 when it cuts out on an OBD 0 computer. and your friend apparently has a USDM ECU to be able to run that fast
Old Dec 9, 2007 | 02:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">
So tell me, can you really go 120pmh in any other gear but 5th?? so that part is irrelavant and likely your speedo is off if it says 120 when it cuts out on an OBD 0 computer. and your friend apparently has a USDM ECU to be able to run that fast</TD></TR></TABLE>
I aint stupid...I was saying if there was a fuel cut in every gear, besides the rev limiter and mine does read right cuz I compared it to a couple of friends to make sure... gosh
Old Dec 9, 2007 | 02:50 PM
I aint stupid...I was saying if there was a fuel cut in every gear, besides the rev limiter and mine does read right cuz I compared it to a couple of friends to make sure... gosh</TD></TR></TABLE>
Damn fool, quick to get offended aren't ya'? I wasn't even being offensive which is what's so funny, it was sarcastic humor at best, just relax man, you'll know real quick if I'm bashing you believe that. other than the rev limiter the only fuel cut your ECU has is the one you experienced @ top speed. switch it out for a usdm ecu or just reprogram yours and you'll be all good
Old Dec 9, 2007 | 10:29 PM
gunnerman's Avatar
i got the same code after replacing a trans...make sure the cable is seated properly in the VSS...throwing code 17 will prevent vtec from hitting...means less power. after i pushed in the wire, i guess it was loose, the code went away. problem solved. Does your speedo work? mine didn't while throwing the code.
Old Dec 9, 2007 | 10:33 PM
boosted dohc zc's Avatar
Damn fool, quick to get offended aren't ya'? I wasn't even being offensive which is what's so funny, it was sarcastic humor at best, just relax man, you'll know real quick if I'm bashing you believe that. other than the rev limiter the only fuel cut your ECU has is the one you experienced @ top speed. switch it out for a usdm ecu or just reprogram yours and you'll be all good </TD></TR></TABLE>
but uh why would you need to go that fast on the road in the first place?
Old Dec 10, 2007 | 09:38 AM
Default Re: code 17 vss(vehicle speed sensor)? (boosted dohc zc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted dohc zc &raquo;</TD></TR><TR><TD CLASS="quote">
but uh why would you need to go that fast on the road in the first place? </TD></TR></TABLE>
We are all just "assuming" it's not on regular public roads to avoid any "keep it off the streets" arguments that would really drive the op off course. Since there are actually places that you can drive 120+ legally (race track for example) we should just leave it at that
Old Dec 11, 2007 | 06:34 PM
Okay my bad. I like my jdm ecu! Its kickin *** besides the stupid fuel cut.
Old Dec 11, 2007 | 06:37 PM
HIGHWAY RUNS!!!
Plus I always lose on the top end tho I won the accelerating part of the race, lol
SiR_Injected
Oct 21, 2007 07:24 AM
chancock
Sep 25, 2007 09:39 AM
aaronhume
Nov 21, 2006 12:00 PM
klepsta
Jul 28, 2004 07:53 AM
crxsi_rcr
Mar 20, 2002 06:08 PM
