ideas on cooling my 99 EX
This is my daily driver, which means that though i'm not running it hard (kinda), it still goes through a lot of abuse, so i'm looking for mean of keeping temp. under the hood cool.
I know a few already, Aluminum radiator, oil coolers, but what else is out there, thanx in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almerricking »</TD></TR><TR><TD CLASS="quote">wrap your exhaust manifold</TD></TR></TABLE>
Theres pro's and con's to that.
Aluminum radiator would be more than enough to keep a stock motor cool.
Unless your running boost, or a built motor, heat should not be an issue if your waterpump is working correctly.
an upgraded aluminum radiator is always a good idea, especially if you're planning on doing future mods. plus I assume you have 100k on the radiator you have now. So if you are planning on replacing the factory radiator, might as well upgrade.
EKstacy
10
Apr 9, 2008 05:25 AM
bgod
Feb 6, 2003 11:57 AM
