PLW wireing & which power source
Old Dec 2, 2007 | 10:03 PM
0TT's Avatar
0TT
Default PLW wireing & which power source
OK Hondata reccoments using switched live form the fusebox and the same reference ground as the PLX, but PLX devices reccomend using power & ground from the ecu feed line as close to the ecu as possible so they can have the same reference ground & voltage.
What have you guys hooked it upto and did you use Hondata to compensate the voltage difference to get the readings equal?
Old Dec 2, 2007 | 11:07 PM
Legion's Avatar
* B A N N E D *
Default Re: PLW wireing & which power source (0TT)
The power can be from any +12v switched power source. Doesn't matter where.
The ground should be at the ECU. Having a distant ground "supposedly" causes the display to read .1 or .2 off.
Old Dec 2, 2007 | 11:18 PM
0TT's Avatar
0TT
Default Re: PLW wireing & which power source (Legion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legion &raquo;</TD></TR><TR><TD CLASS="quote">The power can be from any +12v switched power source. Doesn't matter where.
The ground should be at the ECU. Having a distant ground "supposedly" causes the display to read .1 or .2 off.</TD></TR></TABLE>
PLX highly discourages using the cig lighter power as an example. because of voltage variations.
Old Dec 2, 2007 | 11:42 PM
Legion's Avatar
* B A N N E D *
If you want to nit-pick and do everything as perfect as possible:
1. Splice the ground wire into the ECU ground.
2. Go to radio shack and buy a 12v automotive relay:
3. Run a +12v power wire from the positive terminal of your battery to the relay
4. Wire an inline 5-amp fuse into the power wire
5. Ground the relay to anything you want. There are lots of random places under the dash to ground it to.
6. Power the relay with any +12v switched power. I personally used the power wire from the cigarette lighter because it already has a spade terminal on it that plugs directly into the relay.
7. Connect the PLX power wire to the relay output.
Voila.
Old Dec 3, 2007 | 07:11 AM
0TT's Avatar
0TT
anyone else with an opinion on this, the above idea is ok but I wouldnt need the relay as i could instead use a swiched +12v from the fusebox. I just want to hear what other people have done for their setups!
lude98SH
Feb 22, 2008 06:56 AM
mattm868
Sep 21, 2007 09:35 PM
dsadas89das78934
Jul 6, 2004 04:19 PM
shadowdawn
Oct 10, 2002 12:29 AM
