91 accord won't start, need help
i have a 91 accord lx auto that i was having problems with it shifting i found that the auto trans computer was fried. i replaced it and started the car it started for about thirty seconds, then died. i tried to restart it and no luck. went and started looking under the hood for problems. found there was a lot of oil in the spark plug tubes. so i replaced the valve cover and spark plug seals, while i was at it i replace the plugs, wires, cap, and rotor. car still will not start, it cranks and cranks but will not turn over. it has a new battery and i have even tried to jump it with another car, no luck. if anyone can give me some ideas i would greatly appreciate it.
first do the simple checks. Check to make sure its getting fuel, Second check to make sure its getting spark. If you need help doing those let me know
thanks man turns out to be the distributor, i wasn't getting spark. car runs now but i am still having two problems that i noticed. 1. the green "S" light is flashing when i drive. 2. on the instrument cluster there is a picture of the a car well behind the car is a red light that say brake lamp, all three break lights work fine. and the brake fluid is also fine please help
