valve ticking
ok put in lucas treatment, oil just changed, fuel injector treatment, valves are still ticking loud, idle drops while siting at lighs, a whining sound like a go kart when i accelerate??? any takers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRBrent »</TD></TR><TR><TD CLASS="quote">ok put in lucas treatment, oil just changed, fuel injector treatment, valves are still ticking loud, idle drops while siting at lighs, a whining sound like a go kart when i accelerate??? any takers?
do a valve adjustment. and as for the whining noise, if your timing belt has too much tension on it, when u accelerate it will make a whining noise. as for your idle there is a idle adjustment screw on ur throttle body u can loosen or tighten to adjust your idle.
</TD></TR></TABLE>do a valve adjustment. and as for the whining noise, if your timing belt has too much tension on it, when u accelerate it will make a whining noise. as for your idle there is a idle adjustment screw on ur throttle body u can loosen or tighten to adjust your idle.
thanks for the timming tip i need to be replaced anyhow, the idle started when the valves did it ides fine then will randomly drop when sitting still wont stall but drops real low. Help?
lilxvtecxpwr
11
Sep 17, 2002 05:58 PM
