Spring Question?
i installed some used h&r race springs on my ek i got from a buddy... just installed them yesterday but the front of the car is a about half an inch higher than the rear its not my first pair of springs i install so yes the fronts and rears are where they are supposed to go.... do the springs take time to settle or what???
pictures :
SAME SPRINGS ON MY EG COUPE : (this is the drop i thought i was gonna get.. if not similar)
Modified by Midori Green at 6:59 PM 12/3/2007
pictures :
this is my second pair of these springs i had them on my eg coupe and the drop was about half an inch lower in the front so it was very noticeably lower in the front ... so i dont get why they sit like this in my ek
the front springs are a little bit higher than the rears by the way.... im guessing thats because of the weight of the car is more towards the front
pictures are up.. what do u guys think?? i believe the drop should be the same if not very similar because even tho the cars are different years obviously the suspension is pretty much the same
when i first installed my skunk2 springs, the front was higher then the back and i was like wtf? then after about a day or 2 they were lower then the rear.
remember more coils in the front then the rear.
springs dont need to settle. and even if they did, theyd settle evenly which would put you where you are now. id double check your work. did you install just the springs or the springs and struts together. maybe the strut is not reinstalled properly. dont they have that groove that has to line up? its been a while since ive had my suspention apart so i really dont remember.
no i just installed the springs by themselves... one thing i suspect is that those are the wrong springs because i got them from somebody on a forum who told me they were the right ones so im guessing he was lying just to sell them
just remember the Thicker spring needs to be in the front and the skinnier one goes on the back. If you got it backwords u have no choice but to switch them
whats the number on the spring of the ek h&r race springs??? cuz i wanna see if they match up with the number on mine to see if they are the right ones or if i got played
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_B »</TD></TR><TR><TD CLASS="quote">51865</TD></TR></TABLE>
is this number for h&r race or sport??? because i have the race springs
