oversized vavles
Old Dec 2, 2007 | 05:03 PM
Lsweez's Avatar
Default oversized vavles
what are some of he pros and cons of oversized +5mm vavles, are they really worth it of should i just stay with stock vavles?
Old Dec 2, 2007 | 05:28 PM
ilikehonda's Avatar
Default Re: oversized vavles (Lsweez)
whoa! 5mm? thats a lot. you better be running a small cam. with forced induction it is helpful put with all motor its more ideal (imo) to run a larger cam and more compression. i would no oversize the valves. if you did maybe just stick to the intake side. on the h22's its a good thing to open up the intake side by .5mm.
Old Dec 2, 2007 | 07:45 PM
night's Avatar
Default Re: oversized vavles (ilikehonda)
obviously he meant .5, and i woudl stay with stock. unless you are having the head ported to match/take advantage of a larger valve it is a bad thing to do.
Old Dec 2, 2007 | 08:36 PM
Combustion Contraption's Avatar
Default Re: oversized vavles (night)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by night &raquo;</TD></TR><TR><TD CLASS="quote">obviously he meant .5, and i woudl stay with stock. unless you are having the head ported to match/take advantage of a larger valve it is a bad thing to do.</TD></TR></TABLE>
are you sure about that?
Old Dec 3, 2007 | 02:51 AM
Natural Aspirations's Avatar
Default Re: oversized vavles (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
are you sure about that?</TD></TR></TABLE>
You would know more on this than I would CC but normally putting a bigger cap over the same hole does not give any benefit, just a larger blockage for the air to flow around.
Old Dec 3, 2007 | 06:05 AM
AccordSleeperZzZ's Avatar
Default Re: oversized vavles (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">
You would know more on this than I would CC but normally putting a bigger cap over the same hole does not give any benefit, just a larger blockage for the air to flow around.</TD></TR></TABLE>
that's basically what i have heard as well. i believe, more specifically,it was something along the lines of "unless you're running an extremely ported head with a ton of flow / or you're planning on going forced induction, just stick with stock sized valves." for the same reason stated above^
could have been misinformed though.
Old Dec 3, 2007 | 06:45 AM
Depends on the size of the original "hole" to begin with and if the head was under/over valved from the factory.
Old Dec 3, 2007 | 02:12 PM
Lsweez's Avatar
thanks alot guys. staying with stock i will do.
SolLesHonda
Nov 7, 2006 06:05 PM
ol'rex
May 6, 2006 11:37 PM
Black R
17
Jun 2, 2005 11:18 AM
BlkChryKord
May 27, 2004 03:27 PM
Irishweird00
May 22, 2004 08:26 AM
