knock from front wheel
My friends 94 integra is getting a knock coming from the driver front wheel. It occurs mostly when turning and slow acceleration. Under heavier acceleration it does not happen as much. I was thinking an axle. It almost feels like it is mis-firing the way it studders sometimes but we replaced spark plugs and spark plug wires which make the car run a bit smoother but made it more obvious that it is not and spark problem. Any input is much appreciated. Thanks
mine did that too, till one day my ball joint took a ****. turn the wheel the whole way to one side, and look at them, if you can see its torn up, or damaged, or metal shavings, replace it.
hmmm knocking jack up the car check the axels and the ball joint. tie rods easy way to do it.... jack it up pull up and down, side to side on the "axels" they move alot replace them.... now the tie rods and ball joint are easy to check... put one hand at 12 oclock and one at 6 oclock quickly push and pull if moves bad ball joint... now ties rod same thing at 9 and 3 oclock..... hit me back
DeDonDeRosa
Sep 9, 2006 06:43 PM
Dwight Schrute
12
Aug 26, 2006 12:04 PM
slowteg550
Suspension & Brakes
Jul 21, 2006 07:30 AM
99teggsr
Feb 12, 2005 01:46 PM
cdog19
Sep 21, 2003 07:04 AM
