Rod Bearings and Honing Question for LSVTEC help
Old Dec 2, 2007 | 04:05 PM
lsvtek's Avatar
Default Rod Bearings and Honing Question for LSVTEC help
Hi, I have a quick questions. I am in the middle of doing a LSVtec conversion and was wondering if it is mandatory to change the rod bearings. My motor only had 94k on it and the rod bearings looked good. Also my cylinder walls are smooth with no deep scratches inside, and I was wondering if I still need to hone it. I am puting in PR3 Pistons with new rings.
Thanks in advance
Old Dec 2, 2007 | 04:20 PM
b20vtech's Avatar
Default Re: Rod Bearings and Honing Question for LSVTEC help (lsvtek)
always hone the walls when doing a rebuild.... run ur finger nail accross the surface of all ur bearings, if it catches then u will need to replaced that bearing...
Old Dec 2, 2007 | 04:24 PM
lsvtek's Avatar
Default Re: Rod Bearings and Honing Question for LSVTEC help (b20vtech)
I did, all my bearings are smooth with no scratches on them. But hone cylinder walls for sure then? kind of tried to avoid it since the block is still in the car
Old Dec 2, 2007 | 07:47 PM
night's Avatar
if you are putting new rings you have to hone or they will likely never seat.
and you can hone it in the car with a drill and the stones, but cleanliness and quality is always a question then.
Old Dec 2, 2007 | 08:18 PM
Combustion Contraption's Avatar
I never have time to do it right the first time, but i always have time to do it right the second.
Old Dec 3, 2007 | 03:32 PM
lsvtek's Avatar
Default Re: (Combustion Contraption)
bump for more help please
Old Dec 5, 2007 | 08:31 PM
lsvtek's Avatar
Default Re: (lsvtek)
bump for more help. need some help on honing. I have the block in the car and also the crank is stil in but my cylidner walls are smooth and you can see some hatching still. somepeople told me I dont need to hone, is this true? Thanks
Old Dec 5, 2007 | 10:35 PM
h46it's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">I never have time to do it right the first time, but i always have time to do it right the second.</TD></TR></TABLE>
Greatest quote ever!
Old Dec 6, 2007 | 09:01 AM
CerealKiller's Avatar
you should pull the block out and have a local shop hone it. better safe than sorry.
Old Dec 6, 2007 | 11:46 AM
RYNO48's Avatar
Default Re: (CerealKiller)
Honing isn't going to really make a huge mess. Just wet down a rage and place it at the bottom of the cylinder. You have the pistons out therefore you have the oil pan off so stuff isn't going to be in the pan. Each cylinder only takes 1 to 2 minutes to do. I wouldn't take it out. That would be a waste of time. Rub some oil on the stones, use a moderate to slow speed with the drill and make sure you keep it moving up and down and wipe the cylinders after your done. Look to make sure you got good cross-hatching around the cylinder. So easy you have to do it.
nemesis25
Aug 2, 2012 11:30 AM
dbb95ex
Aug 12, 2009 09:07 AM
MeathooK
Jul 14, 2008 06:23 AM
H22isnotabigblock
Dec 27, 2006 12:25 PM
Revi
Sep 26, 2006 06:16 AM
