map sensor question for crx with b16a.
just unplug the harness off the firewall and plug it to the throttle body OR just leave it on the firewall....wither way works....I left it on the firewall, when i ran a gsr and a b16..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richboi »</TD></TR><TR><TD CLASS="quote">just unplug the harness off the firewall and plug it to the throttle body OR just leave it on the firewall....wither way works....I left it on the firewall, when i ran a gsr and a b16..</TD></TR></TABLE>
so where would i plug the map sensor off the firewall into the throttle body?
u said u had both the map and tps sensor on the throttle right?....just plug it into the map thats on the throttle......which should be the sensor thats on top
well i was talking about if i used the one on the firewall, but ill just extend the wires to reach to one on the throttle body map senor. so i wont need the vaccum line at all then right?
just leave it on firewall, and there should only be one vacuum line that u have to run to the throttle...should be that red line that comes from the purge canister (which u already have hooked up)
SuicideSlide
May 16, 2005 01:47 PM
