Cylinder pressure direct link...
Old Dec 2, 2007 | 02:03 PM
TDogg Teg's Avatar
Default Cylinder pressure direct link...
Looking for a link or info to normal cylinder pressures (B series preferably) to match corresponding compression ratio. Ex: 10.5:1 = ??? psi normal pressure.
Old Dec 2, 2007 | 04:04 PM
Legion's Avatar
* B A N N E D *
Default Re: Cylinder pressure direct link... (TDogg Teg)
You're going to get a lot of different answers. The best way to check your compression is to look for major differences from one cylinder to the next. The actual number is not important, since all 4 cylinders aren't going to lose compression at the same rate (cyl. 2 and 3 generally wear out the fastest).
Plus some people measure compression at WOT, some don't, some remove the injector plugs, others don't, some measure on a cold engine, others on a hot engine, some use shitty HF gauges... You get the point. Everyone's got a different number. The important part is that the 4 cylinders all have roughly the same compression.
Old Dec 2, 2007 | 04:16 PM
TDogg Teg's Avatar
Default Re: Cylinder pressure direct link... (Legion)
Thanks, bro.
Rotting Prelude
Dec 3, 2017 08:47 AM
northcb7
Jun 8, 2009 12:31 PM
buddy190
Mar 27, 2009 05:03 PM
Dave_Dc2
Nov 3, 2008 06:29 PM
Ragezero76
May 15, 2002 04:17 PM
