Best grounding spot in 94+ Integras?
Old Jun 26, 2002 | 12:03 AM
Calavera's Avatar
Default Best grounding spot in 94+ Integras?
Where to ground the Head Unit to?
Also, where is the best place to ground your amps in the trunk in 3door Integras? My amp is located in the trunk right next to the rear seats...below the rear strut bar if that helps.
Old Jun 26, 2002 | 12:15 AM
DuNkiN's Avatar
New User
Default Re: Best grounding spot in 94+ Integras? (Calavera)
i used the harness to ground the headunit, but i guess you can just run the wire anywhere thats metal, that should work fine. I have my ground for my amp on the wall of my spare tire well. if you lift up your trunk board, you'll see that theres plenty of room there on the back side of the wall and its easy to run the wire up from there. i also have my cap mounted there just to let you know how much room there is.
Old Jun 26, 2002 | 01:13 AM
Calavera's Avatar
Default Re: Best grounding spot in 94+ Integras? (DuNkiN)
How'd you secure the wire to the wall in the spare tire well? I don't recall seeing any bolts or screws there...except the humongous screw thing that holds the spare tire in place.
Also, do you happen to know if the bolt that holds the bottom part of the rear seats in place would make a good ground?
Old Jun 26, 2002 | 04:47 AM
acuradriva's Avatar
i used the bolts under the seats and under the strut bar thingie they both work.
Old Jun 26, 2002 | 12:52 PM
GSRaCeRbOI's Avatar
as long as its short, is bare metal it should be OK.. you can make your own grounding points as long as your not drilling into wires, gas tank, electrical components, etc.. just make sure its bare metal.. or sand down that area so that it is.. then add a screw...
Old Jun 26, 2002 | 01:12 PM
Mav#4531's Avatar
Default Re: Best grounding spot in 94+ Integras? (GSRaCeRbOI)
I used the screw for the spare tire. It works perfect.
[Modified by Mav#4531, 11:12 PM 6/26/2002]
Old Jun 26, 2002 | 08:14 PM
t's Avatar
t
Use the 10mm bolt on the metal cover over the ABS lines.
Old Jun 26, 2002 | 08:44 PM
Calavera's Avatar
Default Re: Best grounding spot in 94+ Integras? (t)
Aye, me RS gots no ABS.
Old Jun 27, 2002 | 12:23 PM
Volcom's Avatar
Maybe something under the rear seats? I don't remember what it looked like under there when I did my system. Just a thought.
Old Jun 27, 2002 | 10:09 PM
Calavera's Avatar
Default Re: Best grounding spot in 94+ Integras? (Volcom)
I just teared the rear appart and re-organized all the wires and ****.
Cut the ground wire to about 8". It was originally more than 35" long.
Organized all the speaker wires, RCA's, power wires, remote wire so that they're not all over the place beneath the rear seats.
Also seperated the RCA from the power wire as much as I could. I heard the speaker wires don't matter so two of them are very close to the power wire.
Used ziptie to make it alot more clean and neat.
The ground wire is not on a stock bolt, but rather, the installer drilled a hole in a thin metal plate below the rear seats and attached it there. There's a gap beneath the plate so the screw does not penetrate anything that it shouldn't.
Did I do anything wrong here? I can still hear a faint engine noise from the deck.
Old Jun 28, 2002 | 08:14 AM
o_Rage_o's Avatar
try grounding your rca, (the thin wire on rca cables is for ground..not remote like most people think) to do this, ground near the deck, and ground near the amp (ie. both ends)
-Rage
Old Jun 28, 2002 | 11:55 AM
Calavera's Avatar
Default Re: Best grounding spot in 94+ Integras? (o_Rage_o)
Would it be okay to ground all the RCA ground wires to the same spot? Or should I find one for each?
Old Jul 4, 2002 | 11:58 AM
philly-O's Avatar
same spot would be the best but would otherwise it will work else where.
Old Jul 5, 2002 | 07:37 AM
acuradriva's Avatar
Default Re: Best grounding spot in 94+ Integras? (peichie)
ground them in different spots since the amp is in the back. and the rca's get grounded near the radio.
Old Jul 5, 2002 | 01:48 PM
o_Rage_o's Avatar
Default Re: Best grounding spot in 94+ Integras? (acuradriva)
Old Jul 5, 2002 | 03:40 PM
Calavera's Avatar
So I ground the RCA's near the headunit, and ground the RCA's on the amp side in different places?
dem0nk1d
Audio / Security / Video
Feb 11, 2011 05:37 AM
MilanoRedDashR
15
Jul 3, 2009 05:44 AM
ZooYorkGang
Honda Civic (2001 - 2005)
Jun 24, 2008 04:18 PM
Odessa
19
Jul 23, 2004 07:55 PM
juniordc2
22
Jul 18, 2004 09:58 AM
