Replacing and (re)programming keyfob for rsx
so obviously i lost my keyfob. i found a replacement on ebay that says "free programming." Just wondering if I can program it myself or would i have to take it to the acura dearlership and have them do it? Thanks for the help
it's not hard you can do it yourself.
You must complete each step within 5 seconds of the previous step to keep the system from exiting the programming mode.
1. Turn ignition switch to ON (II)
2. Press the LOCK or UNOCK button on one of the remotes. (An unprogrammed remote can be used for this step.)
3. Turn ignition switch to LOCK (0)
4. Repeat steps 1, 2 and 3 two more times using the same keyless remote used in step 2
5. Turn the ignition switch to ON (II)
6. Press the LOCK or UNLOCK button the same remote. Make sure the power door locks cycle to confirm you are in programming mode.
7. Press the LOCK or UNLOCK button on each remote you want to program. Make sure door locks cycle after you push each remote button to confirm system has accepted the remote.
8. Turn the igniton switch to LOCK (0) to exit programming mode.
9. Test remote(s)
9. Test remote(s)
9. Test remote(s)
9. Test remote(s)
I know that you can only have three keys programmed to your car at a time.
Those instructions should work. If they don't after multiple times of trying, it's got to be the fob. Only other option would be to go to the dealership and pay out the clams to have them tell you that the fob doesn't work.
As an FYI, there's a good video on youtube that's a bit easier to refer to than typed out directions.
9. Test remote(s)
9. Test remote(s)
lsvtechatch92
Apr 6, 2009 10:13 AM
