Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
NEED HELP ON TURBO D17
Old Dec 2, 2007 | 07:58 AM
DHARD01's Avatar
Default NEED HELP ON TURBO D17
I GOT 02 D17YA2 CIVIC. WITH A PRECISION T3T4 TURBO. GREDDY FMIC. VORTECH FMU 12:1. 38MM TIAL WASTEGATE. GREDDY TYPE S BOV. ANYWAY I KNO I GOT TO GET THE CAR TUNE. BUT I HV SOME PROBLEMS. THE CAR RUNS FINE UNTIL I GET UP ON IT. IL B DRIVING IT LIKE AT 30 MPH IL DOWNSHIFT AND FLOOR IT N IT SPOOLS UP BUT THEN WHEN IT HITS LIKE 5K RPM IT STARTS BOGGIN DOWN. SOMETIMES ILL RUN PERFECT N WONT DO THAT SO IDK WATS THE PROBLEM. CAN U HELP?
Old Dec 2, 2007 | 08:04 AM
Tu MaDre's Avatar
Default Re: NEED HELP ON TURBO D17 (DHARD01)
please refix your spelling errors
Old Dec 2, 2007 | 08:41 AM
roost's Avatar
* B A N N E D *
sounds to me like you asnwered your own question.
and by assumption sounds me to like you're going to "blow your **** up" driving like that on an untuned car with no real tuning device.
Old Dec 2, 2007 | 09:01 AM
katzenjammer84's Avatar
I wouldn't be getting on it til you had it properly tuned. I'd hope that's pretty common sense, but unfortunately common sense isn't so common.
Old Dec 2, 2007 | 09:08 AM
skUnK2jdm's Avatar
Default Re: (katzenjammer84)
get it tuned fool
Old Dec 2, 2007 | 09:42 AM
D17alltheway's Avatar
Default Re: (skUnK2jdm)
I'd recommend a greddy plug-n-play but if you ballin... K pro
Old Dec 2, 2007 | 09:52 AM
Boilermaker1's Avatar
You're running a rising rate regulator on a car that has a constant pressure (returnless) system. It doesnt work, and you dont have enough injector to keep up with the air flow.
Problem solved.
No go buy a real fuel solution and some injectors and do it right.
Old Dec 2, 2007 | 10:56 PM
tfnaaf's Avatar
What he said ^^^
Old Dec 3, 2007 | 03:21 AM
daddy's Avatar
Default Re:
ppl never cease to amaze me.
Old Dec 3, 2007 | 11:36 AM
DJaeMac's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DHARD01 &raquo;</TD></TR><TR><TD CLASS="quote">IL B DRIVING IT LIKE AT 30 MPH IL DOWNSHIFT AND FLOOR IT N IT SPOOLS UP BUT THEN WHEN IT HITS LIKE 5K RPM IT STARTS BOGGIN DOWN. SOMETIMES ILL RUN PERFECT N WONT DO THAT SO IDK WATS THE PROBLEM. CAN U HELP?</TD></TR></TABLE>
car needs to be tuned...
had same problem...
tune car..and it should work fine thereafter
gsr x civic
Aug 31, 2007 08:18 AM
60-1
Nov 5, 2003 03:21 PM
bluebullet
Apr 16, 2002 04:45 PM
ElectronVTEC
Feb 18, 2002 04:36 PM
