o2 sensor ?
might be a dumb question might not...just wondering im finishing up my b20 and i converted from 0bd0-obd1 swap is a b20b (obd1) just wondering do i get an o2 sensor for my 91 civic or do i get it for a obd1 ls ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grey_ghost »</TD></TR><TR><TD CLASS="quote">might be a dumb question might not...just wondering im finishing up my b20 and i converted from 0bd0-obd1 swap is a b20b (obd1) just wondering do i get an o2 sensor for my 91 civic or do i get it for a obd1 ls ?</TD></TR></TABLE>
If you would have just thought about this a little longer you would have realized you need the obd 1 4 wire o2. search would have found that in about .00245 seconds
And since I'm in the spoon-feeding mood,
WHT - WHT/RED wire goes to D14 which is O2 Sensor Input
BLK - ORG/BLK wire goes to A6, which is Heater Control
GRN - GRN/WHT wire goes to D22 which is Sensor Ground
BLK - YEL/BLK wire goes to A25 which is Sensor voltage (you can also splice into the power junction harness at the driver side shock tower harness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez »</TD></TR><TR><TD CLASS="quote">And since I'm in the spoon-feeding mood,
BLK - YEL/BLK wire goes to A25 which is Sensor voltage (you can also splice into the power junction harness at the driver side shock tower harness)</TD></TR></TABLE>
