Under 1/2 tank = bad????????
Old Dec 1, 2007 | 11:40 PM
GSR in progress 96's Avatar
* B A N N E D *
Default Under 1/2 tank = bad????????
I was just wondering why some people say it is bad to drive their turbo'd car with under a half tank of gas.
Old Dec 1, 2007 | 11:53 PM
Dunc's Avatar
BCICAN
Default Re: Under 1/2 tank = bad???????? (GSR in progress 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR in progress 96 &raquo;</TD></TR><TR><TD CLASS="quote">I was just wondering why some people say it is bad to drive their turbo'd car with under a half tank of gas. </TD></TR></TABLE>
Because some people don't remember to look at their tank and they just go driving....then they decide to make a pull. Except now they only have like fumes left in the tank and then the motor leans out and BOOM
You're completely fine to drive with less than a 1/2 tank if you just keep your eye on it. Generally I stop screwing when I get to 1/4 tank and from then on I'm really easy on the gas.
Old Dec 2, 2007 | 12:33 AM
MidShipCivic's Avatar
Trap door baffled fuel tank or sumped. Do it.
Old Dec 2, 2007 | 04:20 AM
markaria's Avatar
Since a civic tank doesnt hold a lot and if you have less than 1/4 tank then you probably only have a couple of gallons left and you decide to make a full throttle pull your fuel could pool to the back of the tank leaving the pump/fuel pick up sucking air.
this = lean = boom
Old Dec 2, 2007 | 05:35 AM
nsxmatt's Avatar
I ran all my turbo cars down to a 1/8th of a tank or sometimes less with no problems. Your pump will pick up fuel up until the point you are out of gas, that is nowhere near a 1/2, 1/4, or 1/8th of a tank even making a hard pull.
Old Dec 2, 2007 | 05:47 AM
m R g S r's Avatar
yeah i never had a problem with my GSR making pulls under 1/4 tank. . . .
Old Dec 2, 2007 | 06:14 AM
4potnick's Avatar
Default Re: Under 1/2 tank = bad???????? (m R g S r)
1,000,000 to 1 odds. I run my tanks low, never problems
Old Dec 2, 2007 | 08:58 AM
coneheadsracing's Avatar
Default Re: Under 1/2 tank = bad???????? (4potnick)
This goes with tuning, it's easy to get your car a proper tune, it's easy to keep enough gas in your car. There has been plenty of people that have lost thousands from low gas, why risk it.
Old Dec 2, 2007 | 09:04 AM
mike93eh2's Avatar
i usually dont let it get below 1/4 tank...
Old Dec 2, 2007 | 09:18 AM
SteamedRice's Avatar
Default Re: (mike93eh2)
isn't there a way to shut the motor off before you get detonation? like a sensor that recognizes low fuel pressure/ lean air fuel mixture and shuts the engine off?
Old Dec 2, 2007 | 09:20 AM
lambertincorp's Avatar
Default Re: (SteamedRice)
ive seen this happen and its not good
urafag
Jun 30, 2006 05:07 AM
lv6l
Oct 16, 2005 10:17 AM
null.
Jun 22, 2005 07:03 PM
adaml2nv
Jun 6, 2004 04:50 AM
SjCiViCHB
Feb 14, 2003 06:35 AM
