a/f gauge
hey guys i installed my a/f guage again. this time myself... but its not reading right... when am at wot it doesnt show anything. and when im half throttle or something then its like lean and stouch. hmmm its a "powerpro" 02 sensor the one i bought 50 bucks on ebay.. maybe its the 02 sensor giving bad readings? i connected it to the white one. i had it before with my old 02 sensor and it read fine. whould go to rich when i was at wot (wide open throttle) and as i would punch it a little would bounce where it should be at. not sure but my old one had the connection to it with the white and green wire. but as i read here its only the white wire right...? let me know please thanks....
its not listed as powerpro i had to call them to ask what brand it was.its doesnt jump all that much just doesnt seem to be reading good. i have the power supply and ground from the cruis control cables where it was before.... o.O should i try to ground it else where? i think it should be fine ground to that cable though.... let me try to better explain how its working lets say LED'S 1-20 1 being the lean LED 20 being the rich LED. for the mose part 1-6 will be lit up. then while im driving normal cruising down like 1/3 throttle, it will be like 7-9 3 of the LED'S on then when i punch it, it just turns the LED'S off no led's light up... i remember before it would be like led 14 would stay on like right at the rich point. any idea why the dude before had spliced both the white and green cable?
http://cgi.ebay.com/ebaymotors...70311
OK, that's just a stock narrowband Honda 02 sensor. It's useless for an AF gauge, you need a wideband sensor.
My PLX AF gauge uses a VW wideband sensor FWIW...
will a denso 02 sensor be good with my a/f guage? give me good readings? a wideband 300+ is to much money just to see my EXACT a/f mix dont got the cash for that right now. thanks for your help by the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by royalfelix »</TD></TR><TR><TD CLASS="quote">will a denso 02 sensor be good with my a/f guage? give me good readings? a wideband 300+ is to much money just to see my EXACT a/f mix dont got the cash for that right now. thanks for your help by the way.</TD></TR></TABLE>
As long as it's a wideband....I don't know if Denso makes them or not but as long as you get a wideband your gauge should be functional.
Here's a Bosch wideband from the PLX website: http://www.plxdevices.com/prod...nsor/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by royalfelix »</TD></TR><TR><TD CLASS="quote">im talking about the sensor not the gauge.. is the sensor good for that gauge....</TD></TR></TABLE>
ehhhh...that link goes to a sensor.
Maybe this will help, I asked the same questions the other day.
https://honda-tech.com/zerothread/2166604
Also (was posted in my thread I linked you to) be the answer as to why yours isn't reading?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">
You know your gauge is only going to be as accurate as your sensor? Which is only from ~14.3-15.1 AFR... Otherwise it's just a fancy light show.</TD></TR></TABLE>
There's only one sensor if you're older than a '96 I believe, even with the wideband o2 it's basically taking the place of your stock narrowband, and (from what I've gathered, don't quote me please) basically the wideband allows for better tuning and readings of a wider range of a/f ratios.
i connected my a/f gauge to the D14 pin which is the only way to get to the wht and red pin. and it doesnt work. by the way mine has red and white 2 pins next to each other. meaning... not one on top of the other but side by side... any one know where i can get a ecu diagram for my P14 ecu? what i have seen is for the p13... which doesnt coaside with the colors from mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by royalfelix »</TD></TR><TR><TD CLASS="quote"> any one know where i can get a ecu diagram for my P14 ecu? what i have seen is for the p13... which doesnt coaside with the colors from mine.</TD></TR></TABLE>
The colors and pin location are the exact same between P14 and P13. The only differences are a couple more wires on the P13 for VTEC.
Read the pin diagrams again, you are probably counting from the wrong side. I, too thought they were different when i was swapping, but after closer inspection, found them to be identical.
but the colors in the corners dont match. and i have a white red stripe and another white red stripe together not on top of eachother like in the diagram. o.O ok so for sure its a white and red ill try the one right next to it i guess... see what happens. but for sure i got it on the D14 w/e lets see what happens...
im going threw the trouble because i want to. im asking for help not for stupid comments so you can keep that to your self. the colors dont match the freaking diagram the white and red stripe cables are next to each other not even one under the other like in the diagram.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">
Here's a Bosch wideband from the PLX website: http://www.plxdevices.com/prod...nsor/</TD></TR></TABLE>
Which type on this site is for OBD1 93. A or B?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote">
Thanks </TD></TR></TABLE>
It's based on the connector type:
I think a Prelude uses the A type, but you might want to check your car and make sure before you buy anything...
I had a denso o2 sensor. Doesnt work with my autometer af gauge, and it threw CEL for bad o2 sensor when heavy gas load. Wouldn't get it.
as for the AF. Narrowband = buy someone a xmas present instead.
Wideband = worth every cent.
The best way to see what type of O2 sensor you have is to look at it to make sure because there are at least different brands for sell trust me I just went through all that. Now my Prelude runs fine I just need a quite exhaust.
blackeg
Mar 19, 2005 05:16 PM
civicnar
Feb 26, 2004 05:22 PM
