fuel pressure is high am running to rich here
Old Dec 1, 2007 | 06:42 PM
civiceg94's Avatar
Default fuel pressure is high am running to rich here
alright so my fuel pressure is at 55 at idle and 60 when driving. its a h22 in a ek hatch. it has a full exhaust and header and cheap intake. with aem fuel rail and aem fuel pressure regluator. what pressure should it be on. i know this is to high you guys think i can turn it down? any question feel free to ask away
Old Dec 2, 2007 | 06:37 AM
lude98SH's Avatar
Default Re: fuel pressure is high am running to rich here (civiceg94)
At idle it should be 30-37 psi. With the vacuum line on the FPR disconnected it should be at 40-47 psi. This is on a stock motor Im not sure how much if any it would change with bolt ons.
Old Dec 2, 2007 | 06:50 AM
Acidcrakker's Avatar
Default Re: fuel pressure is high am running to rich here (lude98SH)
I have a question relivant to this thread. Ill be testing my fuel pressure within the next month, and Im sure mine is too high as well, Im running rich you can smell it in the air.
How can the fuel pressure be turn up or down?
Old Dec 2, 2007 | 07:13 AM
K-Spec's Avatar
Default Re: fuel pressure is high am running to rich here (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">I have a question relivant to this thread. Ill be testing my fuel pressure within the next month, and Im sure mine is too high as well, Im running rich you can smell it in the air.
How can the fuel pressure be turn up or down?</TD></TR></TABLE>
With a fuel pressure regulator.
At idle, mine sits at 40psi.
Old Dec 2, 2007 | 08:09 AM
Okay so say for instance I bought the AEM FUEL pressure regulator, would I also need a fuel pressure gauge as well or would the regulator tell me what the pressure is?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K-Spec &raquo;</TD></TR><TR><TD CLASS="quote">
At idle, mine sits at 40psi.</TD></TR></TABLE>
Old Dec 2, 2007 | 08:16 AM
98vtec's Avatar
moderator emeritus
u need a gauge.
the only times you need to change fuel pressure is when your injectors are running too high of a duty cycle or when you are running big injectors.
Old Dec 2, 2007 | 08:39 AM
Default Re: fuel pressure is high am running to rich here (98vtec)
Well I guess I would have to take a guess that my fuel pressure is running to high. I can smell fumes a whole lot. Now I have another thread about how to quick fix it, and I assumed some new fuel injectors would clear the issue up.
After searching and reading threads, Ive come to the concluison that new injectors wont nessarilly fix the problem.
My next future upgrade to the car should be the fuel system so as to clear up the running rich. It would include the following. Please chime in and tell me that really isnt needed.
-AEM Fuel Pressure regulator
-AEM Fuel Rail
-Fuel Pressure gauge.
-OEM Fuel injectors
Also would running too rich trip the O2 sensor? It would be a code 1 on OBD1.
Old Dec 2, 2007 | 08:50 AM
98vtec's Avatar
moderator emeritus
you dont need the fuel rail unless you are just wanting to spend money. Dont need to buy new injectors. If you want, take them off and have them cleaned and flow tested.
If your FPR is stock, then your fuel pressure is fine.
Old Dec 2, 2007 | 08:56 AM
Okay so pretty much out of that whole list All I really need is a FP gauge.
Is there a OEM FPR already on my car? What would cause the Fuel injectors to run a higher duty, thats where the ECU comes in right?
Old Dec 2, 2007 | 09:08 AM
98vtec's Avatar
moderator emeritus
in a nut shell, more power = higher duty cycle (theres more to it, you can do your own research on it), higher duty cycle = injectors working harder
every car has some sort of regulator, they just arent adjustable from the factory.
Old Dec 2, 2007 | 09:10 AM
jdmlude5
Guest
Posts: n/a
well i have a question kinda related. what should the fuel presure be if u have the gauge on the fuel filter. would it still be the same?
Old Dec 2, 2007 | 09:33 AM
civiceg94's Avatar
damn i had the question here went off topic all i got was with a stock motor.
Old Dec 2, 2007 | 09:49 AM
98vtec's Avatar
moderator emeritus
Default Re: (civiceg94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiceg94 &raquo;</TD></TR><TR><TD CLASS="quote">damn i had the question here went off topic all i got was with a stock motor.</TD></TR></TABLE>
you are still stock. You havent done anything that would warrant the need to change the fuel pressure.
i run mine at 45psi (stock) and i have cams and many other performance modifications.
Old Dec 2, 2007 | 10:38 AM
mattsnooz's Avatar
buy an aftermarket adjustible FPR. Some even come with a pressure dial that displays your fuel pressure.
Get a good brand like AEM or equivelent. (I don't know if AEM sells them with the pressure guage built in though??)
Don't go above factory fp. Around 40 is fine(depending if your testing with a vacuum)
s0lid
Feb 20, 2012 04:01 PM
digital sol
Aug 6, 2007 05:10 PM
BoOsTiN Dc2
Aug 23, 2004 01:16 PM
tz-devil77
Jan 9, 2004 10:27 PM
