Is a 68mm Throttle Body Optimum for an 89 x 84.5 Build?
Old Dec 1, 2007 | 05:47 PM
7rrivera7's Avatar
Default Is a 68mm Throttle Body Optimum for an 89 x 84.5 Build?
Here is the build:
B18b block sleeved and bored to 84.5mm
Endyn crank girdle with AEBS main studs
Balanced, chamfered, polished crank
ATI crank damper
Eagle rods with ARP bolts
CP 12.5:1 84.5mm pistons
Alaniz Competition VTEC head
Skunk2 Pro Springs, Retainers & Cam Gears
Type R valves
AEBS 68mm throttle
Edelbrock Performer X intake port matched to throttle
BPI CAI stack on 3" piping
SMSP B19 Header
2.5" custom mandrel piping into Magnaflow resonator and Vibrant muffler
RC 370cc injectors
Hondata s300
Skunk2 Pro 2's
Del Sol hydro tranny with 4.78 final & ITR LSD
Competition Stage 4 Strip Series Clutch Kit
Meziere Electric Water Pump
T1 Crankcase Catch Can
Old Dec 1, 2007 | 07:32 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Is a 68mm Throttle Body Optimum for an 89 x 84.5 Build? (7rrivera7)
yea its enough i got one on mine but i should have went 70-72 but it will do the job
Old Dec 5, 2007 | 02:35 AM
7rrivera7's Avatar
Anyone confirm 68mm will flow optimum?
Old Dec 5, 2007 | 03:11 AM
koczeka's Avatar
My setup is very similar to yours.
I have recently upgraded from 62 to 68mm... seems good for me... dyno will measure it on friday.
Old Dec 5, 2007 | 10:39 AM
dinko's Avatar
Default Re: Is a 68mm Throttle Body Optimum for an 89 x 84.5 Build? (koczeka)
buy a 68mm and a 70mm and test em back to back. only way you'll find out...
Professional Products has stock like TB's for an awesome price in those sizes.
Old Dec 5, 2007 | 10:52 AM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7rrivera7 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone confirm 68mm will flow optimum?</TD></TR></TABLE>
Optimum is a relative term. I think with the camshafts youre using, and the plenum volume of the Performer X, a 68 will be enough. Youd probably see a TINY increase in peak HP with a 70mm, but thats just speculation as , as the mantra goes, every build is different.
Old Dec 5, 2007 | 01:57 PM
mx621's Avatar
Default Re: Is a 68mm Throttle Body Optimum for an 89 x 84.5 Build? (Combustion Contraption)
after yester day i am going to say a 68mm is a VERY GOOD choice for a street 2.0L.
Old Dec 5, 2007 | 02:06 PM
7rrivera7's Avatar
Default Re: Is a 68mm Throttle Body Optimum for an 89 x 84.5 Build? (mx621)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mx621 &raquo;</TD></TR><TR><TD CLASS="quote">after yester day i am going to say a 68mm is a VERY GOOD choice for a street 2.0L. </TD></TR></TABLE>
What happened yesterday?
Old Dec 5, 2007 | 03:37 PM
b20beast978's Avatar
x2!
Old Dec 5, 2007 | 04:45 PM
mx621's Avatar
Default Re: (b20beast978)
a pal of mine just made 241/168 on a full street 93 oct, 2.0L using a cut open/ported performer x, and a 68mm t-body. i should have a litttle dyno/ build vid up in a few days. the results were amazing .
Old Dec 5, 2007 | 05:09 PM
bignewtCA's Avatar
Default Re: (mx621)
get the h22a throttle body. deep throat intake noise
Old Dec 6, 2007 | 03:17 AM
7rrivera7's Avatar
Default Re: (bignewtCA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bignewtCA &raquo;</TD></TR><TR><TD CLASS="quote">get the h22a throttle body. deep throat intake noise</TD></TR></TABLE>
What size is the H22 throttle body? Is it a bolt on to a b-series intake mani?
Old Dec 6, 2007 | 04:45 PM
Chris Tune's Avatar
Default Re: (7rrivera7)
What size is the H22 throttle body? Is it a bolt on to a b-series intake mani?</TD></TR></TABLE>
60.8 at the head... and yes...
and yes to the original question... but i hardly think optimum...
7rrivera7
25
Jan 26, 2010 06:45 AM
7rrivera7
37
Feb 17, 2009 01:50 PM
7rrivera7
Apr 7, 2008 03:04 PM
7rrivera7
56
Dec 13, 2007 07:30 PM
7rrivera7
24
Nov 14, 2007 04:47 AM
