removing civic 96 coupe ej8 fender!!!
hi.
i checked and searched... i can't find a detailed guide on how to remove a fender. i got all the screws and bolts out... but there's these weird screw like things that can't be twisted out...
does anyone have experience with getting these out?
i tried to ply it out... but it doesn't work. any suggestion or help would be most appreciated. thanx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazyhmongboi »</TD></TR><TR><TD CLASS="quote">where are the ones you cannot get out located? wheel well? if so just use a flat head to pop them off</TD></TR></TABLE>
Was thinking the same thing. If anything you can cut them out.
i did it... but i ended up cutting them out... not on purpose. but when i was trying to pry open the screw... they broke off... T.T
but they did come off... and after ruining like 60% of my screws... i found that the flat head is the way to go... and i did the rest like that...
for future ej6 to ej8 people who want to get the fender out...
you put the flat head in the indent of the screw... pry the screw loose, and pull out
i was just confused on how to get them out because they had no screw holes... flat or phillips...
CERRITOS.562
11
Jun 29, 2007 01:44 AM
