need info on removing head....
hey im bout to replace my head gasket on my b20b anybody have any step by step info for me i have never done it before
Modified by 96lsivtech at 2:51 PM 12/1/2007
how much knowledge do you have about car motors? also what tools do you have?
it doesn't take as much knowledge. just need to remember a certain pattern when removing and putting back the head bolts. but you need to torque the head bolts back properly with the right pattern.
mainly remove things around the head such as wire harness, power steering, ac, exuast headers. you need to loosen the tensioner bolt to loosen your timing belt. if you can remove the intake manifold then do so; if you dont want to or can't then make sure you check to see if there is a bracket right beneath the intake manifold. that bracket connects the intake manifold to the block. from there remove the head bolts from the outside to center. putting back, it is very important to torque the head bolts to spec following a certain pattern.
its a good amont of work. but if you want more detail information let me know. i'lll give you a detail explanation.
i good for workn on hondas just never did this particular job i got a regular tools and a torque wrench all i really need is the torque specs and tighting pattern............
The support bracket that you are looking for may have already been removed. If you have loosened all of the intake manifold bolts (from memory, there are nine or ten) and the intake is then removable, there was no bracket.
jdstoledo
Apr 7, 2002 02:35 PM
