code 43 problem
Old Dec 1, 2007 | 12:11 PM
jdm206's Avatar
Default code 43 problem
ok i search and i couldn't find a answer to my question. is it really bad to drive with this code on? and is it really hard to fix.
Old Dec 1, 2007 | 01:40 PM
ef_88_hatch's Avatar
Default Re: code 43 problem (jdm206)
Fuel Supply System
defective or malfunctioning fuel supply system
it could be the fuel pump. or it might be the fuil pump relay. i wouldnt drive it. it might be runing lean.
Old Dec 1, 2007 | 06:18 PM
mra4886's Avatar
hey man most of the time on code 43 its not realy your fuel system its your o2 sensor. i had the same problem before.
gl on the fix.
Old Dec 1, 2007 | 07:23 PM
jdm206's Avatar
Default Re: code 43 problem (mra4886)
oh btw my fuel pump is brand new i just replaced it a month ago.
ok today i just bought a new o2 sensor because i had a cracked in my header so i replaced it. i havent check and see if the code is coming up because it sarted to snow, and got code out. an
Old Dec 1, 2007 | 08:01 PM
gotgsrvtec's Avatar
put gas in it
Old Dec 1, 2007 | 08:19 PM
DA_Boy_626's Avatar
Default Re: code 43 problem (gotgsrvtec)
how do u fix that problem i have the same problem but with mine when the check engine light goes on it stopps boggin dont know wat it is
Old Dec 1, 2007 | 10:18 PM
nihad's Avatar
so did the o2 sensor fix it. MY buddy's 91integra idle weired at start ups it a 100rpms ha i couldn't believe
it my self
Old Dec 1, 2007 | 10:28 PM
jdm206's Avatar
Default Re: (nihad)
i dont know yet im going to see if the code would come up tomarow.
Old Dec 1, 2007 | 10:32 PM
Duane_in_Japan's Avatar
Default Re: (jdm206)
Code 43 means replace the O2 sensor, done many of them, have never seen anything else fix this code personally, so its a high percentage that the O2S will do it for you, add in my vote and go OEM ONLY PLEASE, yes it costs more but worth it in the long run.
Old Dec 2, 2007 | 10:03 PM
jdm206's Avatar
Default Re: (Duane_in_Japan)
ok i guess when i changed my o2 sensor it took the code away. thanks eveyone for the help.
Old Dec 4, 2007 | 09:23 PM
my90da's Avatar
i have a 91 ef si hb with a b18a1 and i was just wondering how many o2 sensors did the car come with from the factory? I have 3 in my header, 2 in the top, and 1 before the cat. only one is plugged in and the car is idling funny and at one point in time it gave me a code 43. i also just replaced the thermostat because it was stuck open. Any other knowledge on this issue would be greatly appreciated. Thanks again
Old Dec 5, 2007 | 12:33 AM
rd91sib18c5r's Avatar
Default Re: (my90da)
A 91 si only had one o2 sensor, and I used the same one for my ls swap.
Old Dec 5, 2007 | 03:46 PM
nihad's Avatar
one wire o2 i got like 5 laying around
Old Dec 6, 2007 | 01:06 AM
The single O2 sensor needs to sniff all four header pipes to give good feedback to the ECU, so past the collector and before the cat is where it needs to be, not in one of the header pipes.
str8JDMteggy
Sep 29, 2006 08:27 AM
PhilStubbs
Jan 22, 2005 11:20 AM
dcsportsciv
10
Nov 12, 2004 06:44 PM
OBDI JEDI
May 7, 2003 05:06 PM
89 CRX SI
Apr 22, 2003 03:22 PM
