car idles below 1000 when its cold
Old Dec 1, 2007 | 07:48 AM
ONE-CAM-EF's Avatar
Default car idles below 1000 when its cold
it idles below 1000 whe is cold if i dont keep the gas tap it will shut off until it warms up a little.then while driving it will stay rev at 1000.. i think its the engine coolant tamp sensor but i dont know how to fix that ****...any suggestions?
Old Dec 2, 2007 | 09:36 AM
ONE-CAM-EF's Avatar
Default Re: car idles below 1000 when its cold (ONE-CAM-EF)
bump......does any one knows how to fix it or were is located at?
Old Dec 2, 2007 | 09:42 AM
SIred91's Avatar
Rainman
You need to clean out your throttle body and manifold and IACV/EACV really good, and then have someone that knows what they are doing come and set the idle for you the right way with the screw and iacv.
Old Dec 2, 2007 | 09:57 AM
wiZCo's Avatar
Stouts 'n' Scotch
Well, he didn't mention what motor he has or if he has any CELs, it could be an FITV issue.
Old Dec 2, 2007 | 09:58 AM
SIred91's Avatar
Rainman
Default Re: (wiZCo)
True......I just posted the usual culprit..
Old Dec 2, 2007 | 10:02 AM
ONE-CAM-EF's Avatar
is a stock d15....
Old Dec 2, 2007 | 10:09 AM
SIred91's Avatar
Rainman
Default Re: (ONE-CAM-EF)
MPFI or DPFI?
either way...clean it out and reset the idle.
Old Dec 2, 2007 | 10:32 AM
ONE-CAM-EF's Avatar
Default Re: (SIred91)
ill do that....thanks bro...
Old Dec 8, 2007 | 04:51 PM
EK kid's Avatar
pour some gas
Old Dec 10, 2007 | 07:54 AM
B18c1vicrx's Avatar
well my b series does tha same thing, and i noticed on the backside of my engine my coolant temp sensor isn't plugged into anything, and thats what i think it is with mine too...i just can't find the connector for it, or i may just be too lazy
Old Jan 20, 2008 | 12:31 PM
ONE-CAM-EF's Avatar
Default Re: (B18c1vicrx)
i gt it fix it was a quick ..right under the dizzy there is a skinny pug that goes into the head. that sensor was unplug..i guess i unplug it by mistake when i change mr tranny or something idk well is fix...
z0mby
Oct 22, 2011 04:32 PM
curtie94
Aug 4, 2011 08:03 PM
chrisff521
Jan 19, 2011 06:38 PM
gsxr1k05
Sep 5, 2010 08:39 PM
gsrpowercrx
Dec 7, 2008 06:52 AM
