Power window motor bench test
Hey can someone tell me how i can hook up a power window motor to see if it is good by directly hooking it to power. More specific, which wire is power and which is ground. For both driver and passenger side. Thanks.
I was meant to post this in civic 92-00 section but forgot i was in gdd...
window motor is from a 94 ex..going into a hatch...just hook up the power wires to a car battery or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_conference »</TD></TR><TR><TD CLASS="quote">I was meant to post this in civic 92-00 section but forgot i was in gdd...
window motor is from a 94 ex..going into a hatch...just hook up the power wires to a car battery or something?</TD></TR></TABLE>
PM a mod to get it moved. I'm sure someone there will be able to locate a diagram. Make sure it actually needs 12v before you hook it up. It might run off of 5v or something, and you don't wanna fry it.
Then it should be as simple as hooking up power and ground.
Also, use a multimeter to measure the current draw. Over time, moisture causes corrosion which leads to excess electrical resistance which diminishes current flow and weakens the regulator motor. The current draw should match the current rating stamped on the motor itself.
suradnoh
Feb 5, 2018 05:18 PM
bpeters2
Dec 14, 2015 08:31 AM
all_conference
Dec 2, 2007 12:03 PM
