Emmisions help please
Old Nov 30, 2007 | 11:26 PM
lsdB16aEj1's Avatar
Default Emmisions help please
Failed WA state emmisions, it looks pretty bad
JDM B16a P30 ecu
new plugs, wires, rotor, O2 is a year old or so.
failed cruise so bad they didn't even run an idle test
let me know your thoughts from what the numbers show.
hc (ppm) co% co+co2 (%) o2%
Cruise limit 170 1.2 6 N/A
cruise emmisions 453 11.91 19.41 0.24
cruise result FAIL FAIL N/A N/A
any suggestions will help, i'm leaning towards the cat. because I ran my old d15b turbo on it before the swap. Thanks
Old Nov 30, 2007 | 11:37 PM
PinoyDelSol's Avatar
* B A N N E D *
Default Re: Emmisions help please (lsdB16aEj1)
Try seafoaming your motor, new spark plugs, clean air filter with water and soap and re-oil it back up and do a oil change too.. Thats the best i got. I passed Emissions cleanly with my D15B7 motor with all that done, and i have 200,xxx miles on the motor as well.
Old Nov 30, 2007 | 11:39 PM
lsdB16aEj1's Avatar
Default Re: Emmisions help please (PinoyDelSol)
did seafoam, oil change has under 100 miles on it. filter is k&n cleaned before the test. Plugs were changed at oil change all NGK plugs and wires
Old Dec 1, 2007 | 03:28 AM
pimpinblackcivic's Avatar
sounds like the cat then
Old Dec 1, 2007 | 09:08 AM
lsdB16aEj1's Avatar
Default Re: (pimpinblackcivic)
that's what i've presumed is most likely the suspect.
Old Dec 1, 2007 | 10:42 AM
* B A N N E D *
Default Re: (lsdB16aEj1)
Is your cat still good? And before you went to test your car, did you run your car hard so that your cat can be in operating temperatures?
Old Dec 1, 2007 | 10:56 AM
lsdB16aEj1's Avatar
Default Re: (PinoyDelSol)
I ran the car hard before the test, I always run her hard . I'm not sure if the cat is good, I ran my turbo motor on it for about a year and i have a feeling that all the extra emisions from it may have rotted it out. I think I'm just gonna try one of those bolt on magnaflow replacement ones. I was just curious what everybody thought from the numbers if there could be any additional problems, or simply put, would a bad cat cause it to be that far over?
Old Dec 1, 2007 | 11:21 AM
eg6itr069's Avatar
just try the cat it probably will help a lot....what is your emission for hc co an nox?
Old Dec 1, 2007 | 11:45 AM
lsdB16aEj1's Avatar
Default Re: (eg6itr069)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsdB16aEj1 &raquo;</TD></TR><TR><TD CLASS="quote">Failed WA state emmisions, it looks pretty bad
JDM B16a P30 ecu
any suggestions will help, i'm leaning towards the cat. because I ran my old d15b turbo on it before the swap. Thanks</TD></TR></TABLE>
Old Dec 1, 2007 | 01:36 PM
eg6sirll's Avatar
yea eff a magnaflow cat just get a stock one less worries. and the only thing that really "kills" cats is a car running too rich or if you drove it misfiring for a while. The excess unburned fuel causes the cat to overheat. **** all that tune up bullshit if your b16 is running fine and your not having any driveability issues then i would invest in a new cat, Or if you were cool and had a pyrometer you could tell me the heat differences before and after the current cat and i could tell you if it was bad.
Old Dec 1, 2007 | 01:39 PM
eg6sirll's Avatar
Default Re: (eg6sirll)
also from those numbers it appears you are currently running rich it might destroy that new cat if you just toss it on there . do you have any cels ??
Old Dec 1, 2007 | 01:42 PM
lsdB16aEj1's Avatar
no cels at all. you think seafoaming the engine could have messed up the o2 sensor? i got a cel for an o2 problem a few months back but i reset the ecu and it hasn't come back since.
eg6sirll's Avatar
they also should have done the full test. they should not have ommitted the low rpm test just because you failed the high speed. thats
Old Dec 1, 2007 | 01:43 PM
eg6sirll's Avatar
you could always check it if you have a voltmeter.
Old Dec 1, 2007 | 01:47 PM
lsdB16aEj1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sirll &raquo;</TD></TR><TR><TD CLASS="quote">they also should have done the full test. they should not have ommitted the low rpm test just because you failed the high speed. thats </TD></TR></TABLE>
that's the state for ya
eg6sirll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsdB16aEj1 &raquo;</TD></TR><TR><TD CLASS="quote">no cels at all. you think seafoaming the engine could have messed up the o2 sensor? i got a cel for an o2 problem a few months back but i reset the ecu and it hasn't come back since.</TD></TR></TABLE>
At my work we use this stuff from gm called top engine cleaner, same stuff basically and we run that through all kinds of cars for maintenence with no o2 problems. If you put too much at once it might throw a misfire code but thats ob2. so i wouldnt worry about that. i would look at coolant temp sensor, intake temp sensor, map sensor, ummm injectors sticking.... all these can cause a rich condition. So if all else fails and you cant figure this **** out may have to pay someone
lsdB16aEj1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sirll &raquo;</TD></TR><TR><TD CLASS="quote">you could always check it if you have a voltmeter.</TD></TR></TABLE>
do you know what the voltage should be at by any chance.
Old Dec 1, 2007 | 01:49 PM
lsdB16aEj1's Avatar
bout ready to just swap the single cam back in to save me the hassle lol, just so i can pass emissions at least.
Old Dec 1, 2007 | 01:50 PM
eg6sirll's Avatar
that's the state for ya</TD></TR></TABLE>
that blows. here in texas if your poor and you cant pay to have it fixed after it fails emissions. the state will pay up to 600$ for emissions repairs on your car.
Old Dec 1, 2007 | 01:51 PM
lsdB16aEj1's Avatar
that's nice guess they just want to keep the evergreen state green i guess
eg6sirll's Avatar
should switch between 1.23 volts and like .23 something like that. its the white wire coming off the ecu. the main thing is that it should be switching back and forth while the cars running.
Old Dec 1, 2007 | 01:52 PM
eg6sirll's Avatar
the voltage represents how much oxygen is in the exhaust so if you have a real low reading constantly then it would be running rich.
Old Dec 1, 2007 | 01:53 PM
lsdB16aEj1's Avatar
thanks i'll give it a shot, i'll also check the coolant temp sensor, my iat is new and map sensor can easily be swapped out with one of many i have.
eg6sirll's Avatar
good luck and going home for the weekend..
Old Dec 1, 2007 | 02:24 PM
JLman86's Avatar
hey man i live here in washington too. I battled with this on my built ls. I tryed to fix it all myself, and it didnt work out. YOUR BEST OPTION IS............ go take your car to a shop they charge you a 150 bux for a diagnostic test to tell you what should be fixed, then you take that to the Emission testing place and you get a WAIVER. instead of trying to fix it yourself, save the money you spendin on re-test and just get the waiver. i tryed to do it my way and ended up spending double. its the easyest fastest way to get it done bro, and its good for 2 years so that not bad. leme know if you neeed a hand or have a question about anything else.
chase
