Satin Red: About to talk to the body shop.
Old Nov 30, 2007 | 06:46 PM
Convert's Avatar
Default Satin Red: About to talk to the body shop.
Ooooooookay. So i made a thread:
https://honda-tech.com/zerothread?id=2149941
And decided that the chevy looked like the finish that i wanted. So here i am now. i realize that there is a satin black thread, and the cool fellow with the flat green eg and i have spoken. So, Is there a quality process to making a show quality satin finish? I've heard everything from flattening agent in the clear to buying rust sealer and doing the whole car in that. Its not that i want a show quality finish, just good paint. ANYTHING besides what i have now would be better. My **** is Fugly.
thanks to all the painters.
Old Nov 30, 2007 | 07:11 PM
powerflow's Avatar
Default Re: Satin Red: About to talk to the body shop. (Convert)
There is a quality process for every high quality paint job. Some paint systems have codes for flat, satin and semi-gloss clears. A good paint job like this will use a high quality 2K clear, mixed accordingly to the chosen finish type. Sprayed just like any other 2, 3 stage job. These type of clears do use the flattening agent and/or translucent clears in the mix, along with the gloss clear and hardener. Not all mixes will be the same and will vary from different brands and companies.
Old Nov 30, 2007 | 07:15 PM
fastedie's Avatar
well there is a lot of useful info on the $50 paint thread The rustoleum has several satin products I am using there satin black for my ej with the roll on method. Def not show quality but its tough paint...... Here is the link you can find it at Home depot walmart ect.
http://www.rustoleum.com/produ...SBL=1
Everyone has there own opinion on this topic but its cheap and will give you that satin finish your looking for.
Old Dec 1, 2007 | 10:17 PM
Convert's Avatar
Default Re: Satin Red: About to talk to the body shop. (fastedie)
dually noted. well, while being in the market for a good paint job, im not quite to the point where i want to do the $50 job. but thats not to say that it wont happen.
anyone else? anyone done a satin job that has a suggested combination?
Old Dec 2, 2007 | 06:03 AM
powerflow's Avatar
The only satin jobs I've done have been base clear. You could do a single stage also. But I recommend going w/ base clear.
Old Dec 2, 2007 | 05:40 PM
SockEG6's Avatar
Default Re: Satin Red: About to talk to the body shop. (powerflow)
i've done a couple flat/satin jobs. all base coat, clear coat with matting agent in the clear. i spray glaurit (BASF)
there are several paint companies offering matting agent for their clears. it's still gonna run you the same amount as your normal bc/cc paint job.
Old Dec 13, 2007 | 06:25 PM
Convert's Avatar
Default Re: Satin Red: About to talk to the body shop. (SockEG6)
bumping this back up from the dead. I have combed the internet throughly and still dont have the ca hones to do this confidently. Im half an inch away from just doing the whole thing in the rustoleum satin color. but thats me. who knows. Im ot out for show quality, just trying something different.
Old Dec 13, 2007 | 07:01 PM
SockEG6's Avatar
read this... I've sprayed several things satin/flat with glasurit (BASF) products. and they back it up 100% as long as it is applied correctly.
http://www.carizzmacolors.com/news.php
at the end of the article is a satin red saturn.
Old Dec 13, 2007 | 07:37 PM
Convert's Avatar
thats bangin'. This is the product that i need. I may actually try to grab some of this and spray in the spring.
SockEG6: you the man.
/thread.
Old Dec 14, 2007 | 04:39 PM
powerflow's Avatar
BASF has codes in their RM Diamont line for flat, satin and semi-gloss also. They use some DC clears the BC100 and their flattening agent. BASF Diamont is what I've used to do this type of finish and have had great results.
gotrice16
Paint and Body
May 9, 2009 02:36 AM
xrabb1t
Sep 15, 2005 10:11 AM
aandrewcc
Jul 22, 2005 11:13 AM
caspers_hatch
Apr 25, 2005 11:25 AM
redex94
Sep 22, 2004 01:04 PM
