New springs are loose on new shocks.. bad??
Old Jun 25, 2002 | 08:26 PM
rice_classic's Avatar
Default New springs are loose on new shocks.. bad??
I got a set of Nuespeed sport springs that lower the car about 2" and I also bought some Tokico Blue gas shocks..
After mounting the spring to the shock shouldn't the spring be tight, as in VERY TIGHT? This is with the units out of the car of course. I am able to rotate the spring on the shock after they have been bolted together. The spring isn't so loose that it moves up and down, although. So I'm wondering.. has anyone else had a problem like this or is it normal with new shocks and lowering springs??
I'm in the middle of a huge swap project and could use all the help I could get as soon as I could get it.. Thanx in advance.
Old Jun 25, 2002 | 08:28 PM
89 CRX SI's Avatar
Default Re: New springs are loose on new shocks.. bad?? (rice_classic)
dont worry it will be tight once the cars wirhgt is on it
it is caseu if you look at your new spring and your old one the new one is a lot short er in length.
good luck
Old Jun 25, 2002 | 08:58 PM
andrew dc's Avatar
Default Re: New springs are loose on new shocks.. bad?? (89 CRX SI)
it should be fine when the weight of the car compresses the spring
Old Jun 26, 2002 | 08:13 AM
keithv's Avatar
Default Re: New springs are loose on new shocks.. bad?? (CRX25)
and just make sure it doesn't come out of the top hat.
Old Jun 26, 2002 | 08:40 AM
89 CRX SI's Avatar
Default Re: New springs are loose on new shocks.. bad?? (breaka_1_9)
that would suck you could prolly bend somthing doing that.........
Old Jun 26, 2002 | 09:03 AM
Thanx for the help.. I on my way out to put the springs on.
Old Jun 26, 2002 | 09:32 AM
shortyz's Avatar
yep ive put on neuspeeds on a EG. and your right they just slop around.
before u lower the car off the jacks put your hand in while its lowering slow and line the top of the shock up with the rubber thing on the top. make sure its seated in the bottom also.
dont get your arm caught in the wheel well!
David_ej6
Suspension & Brakes
Mar 20, 2015 04:33 AM
da1lydr1ver
Honda Civic (2001 - 2005)
16
Mar 22, 2014 03:43 PM
instructor74
Suspension & Brakes
Nov 17, 2006 12:30 PM
tianporn
Nov 30, 2004 08:55 PM
WangChung
Jul 17, 2003 01:55 PM
