t3/t4 question! please help
Old Nov 30, 2007 | 02:27 PM
skUnK2jdm's Avatar
Default t3/t4 question! please help
ok this sounds like a noob question but my car has a t3/t4 and it needs to be changed ! what else can i put on there......thing is i dont want to change the manifold! it a drag t3/t4 manifold, what other turbo can i use so i dcan keep my manifold? thanks
Old Nov 30, 2007 | 02:35 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: t3/t4 question! please help (skUnK2jdm)
you are limited to what you can fit in the space unless you flip it around and put compressor on the drivers side. there really sint that much room to cram a big compressor housing agaisnt the block on the one side.
Old Nov 30, 2007 | 02:54 PM
skUnK2jdm's Avatar
Default Re: t3/t4 question! please help (boostedcivicsir)
i heard i can fit any tseries like ex. t3 or t4 ??
Old Nov 30, 2007 | 02:56 PM
Mr. Badwrench
you can run a t4 with an adapter flange but i doubt thatd fit. the outlet on the manifold is a t3 footprint. the t3/t4 turbo is a t3 exh housing.
Old Nov 30, 2007 | 03:21 PM
skUnK2jdm's Avatar
ok so a t3 will fit! does turbonetics make a turbo that will fit? i wanna go with another t3/t4!
Old Nov 30, 2007 | 03:29 PM
e she i's Avatar
any t3 turbo would fit it minus the one w/ the t4 S-cover..i think you could fit an E cover T4 one on but might have to cut the webbing on the block off...
Old Nov 30, 2007 | 03:39 PM
skUnK2jdm's Avatar
Default Re: t3/t4 question! please help (e she i)
ok and the downpipe bolt pattern is all the same for t3?
Old Nov 30, 2007 | 03:50 PM
e she i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm &raquo;</TD></TR><TR><TD CLASS="quote">ok and the downpipe bolt pattern is all the same for t3?</TD></TR></TABLE>
no you gotta choose the same bolt pattern housing if you wanna keep the old dp..
Old Nov 30, 2007 | 04:09 PM
skUnK2jdm's Avatar
and how do the bolt patters go? 5,6,4??
Old Nov 30, 2007 | 05:20 PM
skUnK2jdm's Avatar
So do I just count the bolts??lol
sikid111
Sep 20, 2010 10:16 AM
Sloshy
Dec 17, 2007 07:34 PM
418whpturboD
Dec 2, 2007 05:13 AM
wrx'n you
Nov 24, 2006 05:26 PM
StolenTeg
May 28, 2004 09:58 PM
