help with car alarm
I just finished installing my alarm system on my 94 accord, everything is fine except, maybe its not part of the system but when I arm my system, and I open a door from the outside without unlocking it the alarm doesnt go off.....isn't it suppose to trigger the alarm???What connection did i mess up on???
YOU PROBABLY HOOKED IT UP TO THE WRONG WIRE ON THE ALARM BRAIN. FOR NEGATIVE DOOR TRIGGERS WHICH YOUR ACCORD IS YOU NEED TO USE THE GREEN WIRE FROM THE ALARM BRAIN TO HOOK UP TO THE DOOR TRIGGERS. BUT THIS APPLIES TO VIPER AND PYTHON ALARMS......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SaLvAcIvIc97 »</TD></TR><TR><TD CLASS="quote">YOU PROBABLY HOOKED IT UP TO THE WRONG WIRE ON THE ALARM BRAIN. FOR NEGATIVE DOOR TRIGGERS WHICH YOUR ACCORD IS YOU NEED TO USE THE GREEN WIRE FROM THE ALARM BRAIN TO HOOK UP TO THE DOOR TRIGGERS. BUT THIS APPLIES TO VIPER AND PYTHON ALARMS......</TD></TR></TABLE> Stop yelling, we can hear you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxi15 »</TD></TR><TR><TD CLASS="quote">I just finished installing my alarm system on my 94 accord, everything is fine except, maybe its not part of the system but when I arm my system, and I open a door from the outside without unlocking it the alarm doesnt go off.....isn't it suppose to trigger the alarm???What connection did i mess up on???</TD></TR></TABLE> Make and model of alarm???
How long are you waiting after arming before you open the door?
Does your Accord have a delayed dome light, [stays on for a bit after you close the door]?
94
94
The GreenD16
Feb 4, 2012 04:47 PM
