Suspension question for hatch owners..........
Old Jun 25, 2002 | 08:20 PM
rodrez.'s Avatar
Default Suspension question for hatch owners..........
My friend has a 94DX hatch w/ITR motor, just had local shop add a set of "Energy" brand sway bars, I guess they're made by Energy Suspension. The problem is, they hang really low, and scrape speed bumps, driveways, etc. Has anyone else had this problem? Ever use this brand of swaybar?
Old Jun 25, 2002 | 08:22 PM
shawnhayes's Avatar
Default Re: Suspension question for hatch owners.......... (rodrez)
Yes. And yes.
Here's the problem.
Shawn
[Modified by shawnhayes, 5:23 AM 6/26/2002]
Old Jun 25, 2002 | 08:26 PM
Phil DeVtec's Avatar
Default Re: Suspension question for hatch owners.......... (shawnhayes)
thats an eg right. i just bought my S/T kit for my EK and where that bar goes under the cat, the one for the EK goes on top of it and over the shift linkage.
Old Jun 25, 2002 | 08:29 PM
turboman's Avatar
That looks real unsafe. It doesn't look like it would go on top either. Looks like it would hit the cv joint going over a bump. I'd take it off if I where you.
Old Jun 25, 2002 | 08:32 PM
rodrez.'s Avatar
Default Re: Suspension question for hatch owners.......... (turboman)
thanks for the pic, I haven't had time to get his car off the ground. I guess it's just that brand, cause I'm using ST's front and rear, and I have no problems at all, my car is on 15's, and lower than his. Think he's going to have to pull those off, it's already driving him crazy.
Old Jun 26, 2002 | 03:49 AM
shawnhayes's Avatar
I always recommend stock front bars (they go over the cat, and don't hit squat), and aftermarket rear bars for cars that don't have them.
My $0.02
Shawn
Old Jun 26, 2002 | 09:39 AM
rodrez.'s Avatar
thanks for the info Shawn
Old Jun 27, 2002 | 08:47 AM
XchtmgX's Avatar
i have a stock gsr on my eg and it works great and doesnt scrap at all. i recomend you should run that or a civic si sway bar. stock is good
Old Jun 27, 2002 | 08:55 AM
JeffS's Avatar
Default Re: Suspension question for hatch owners.......... (XchtmgX)
I also have a GSR bar, but I'd look into a LS bar. I think they're smaller than the GSR... something that's desirable.
Old Jun 27, 2002 | 09:03 AM
94CivicSi's Avatar
I don't even understand how that swaybar achieves it's goal. The bar is so long from the pickup point on the LCA to the pivot point, it must provide almost zero torsional resistance. In other words, with that much of a mechanical advantage, it's very easy to bend. I would assume, easier to bend that a stock Si bar.
Regardless, it's one of the most abysmal designs I've ever seen. Get that POS off of there!
Old Jun 27, 2002 | 09:12 AM
memphiss13's Avatar
Default Re: Suspension question for hatch owners.......... (94CivicSi)
it looks like its on backwards
Old Jun 27, 2002 | 09:23 AM
eccentric.ek's Avatar
Default Re: Suspension question for hatch owners.......... (rookie2nr)
stock owns
Old Jun 27, 2002 | 09:31 AM
rodrez.'s Avatar
Default Re: Suspension question for hatch owners.......... (redUSDMhb)
I took a look underneath his car yesterday, and they're friggin low! There's scrape marks all over te bottom part, and his car is on 16's, w/about a finger gap all the way around. They're making even more noise now, then before, so I'm trying to convince him to take them off and sell em on ebay. He's got a stock type R rear bar from a roll over that he bought recently, so we might be using that w/a beaks kit. I had stock bars before, but I'm using ST's now, and I love em. Thanks for all the info fellas.
Old Jun 27, 2002 | 11:13 AM
ek6-crvtec's Avatar
i have the same bar it scraps every now and then but who cares
jdmbapp
Jan 6, 2012 05:27 AM
87CRX
12
Aug 25, 2009 05:51 AM
homer_eps
Appearance Build Threads
Apr 21, 2008 05:23 AM
turbopat11
Suspension & Brakes
Jan 18, 2006 05:23 PM
