Slotted rotors installed wrong direction after 5K should i switch?
Old Nov 30, 2007 | 11:13 AM
HT Chaplain's Avatar
Loved
Default Slotted rotors installed wrong direction after 5K should i switch?
The rotors were installed backward about 5k miles ago. They stop excellent thatswhy i never thought about it,but after seeing a coulple post i realized mine were facing the wrong direction. Should i switch them??
Old Nov 30, 2007 | 02:01 PM
Legion's Avatar
* B A N N E D *
Default Re: Slotted rotors installed wrong direction after 5K should i switch? (HT Chaplain)
It doesn't matter. You'll find hundreds of pics on h-t of them facing either way.
Next time you're stopped next to a new Mercedes, check out its cross-drilled rotors - they put them on backwards now.
In the end, slotted/drilled rotors are 99.9% for looks, so just put them on however you think will look the coolest.
Old Nov 30, 2007 | 04:04 PM
89s1's Avatar
if it REALLY mattered you wouldnt have installed them "wrong" because they would have had "direction of rotoaion" or "Driver/passenger" side labels
Old Dec 1, 2007 | 12:17 PM
Loved
Default Re: Slotted rotors installed wrong direction after 5K should i switch? (89s1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">if it REALLY mattered you wouldnt have installed them "wrong" because they would have had "direction of rotoaion" or "Driver/passenger" side labels </TD></TR></TABLE>
they didnt, so i assuming it doesnt matter they stop perfect
Old Dec 1, 2007 | 10:17 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain &raquo;</TD></TR><TR><TD CLASS="quote"> so i assuming it doesnt matter they stop perfect</TD></TR></TABLE>
It wouldn't be a question of how well they "stop", the primary concern is the direction of the rotor's cooling vanes. The chances are good that the vanes are not directional, in which case the direction that the rotors were installed is not terribly consequential.
Old Dec 2, 2007 | 05:09 AM
Dogginator's Avatar
Daisy... Daisy...
I thought that the slots faced the way that they did (forward looking at the top) to pull the brake pads inwards towards the caliper mounting bracket as the slots sweep by.
Old Dec 2, 2007 | 02:03 PM
Legion's Avatar
* B A N N E D *
Default Re: Slotted rotors installed wrong direction after 5K should i switch? (Dogginator)
As stated, the rotors are only directional if the vanes are tilted. If the vanes are straight, there is no proper direction. Do whatever looks the best.
Old Dec 2, 2007 | 02:07 PM
Legion's Avatar
* B A N N E D *
Default Re: Slotted rotors installed wrong direction after 5K should i switch? (Legion)
I installed mine like this:
Old Dec 2, 2007 | 09:24 PM
CarbonizedDX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legion &raquo;</TD></TR><TR><TD CLASS="quote">I installed mine like this:
I install mine the same way only with the logic that when/if something is on the rotor and the pad is "sweeping" the rotor clean the slot is directional towards the centrifugal forces at work.......... But in the end it doesn't really matter either way...... Hell most people no H-T (and other forums I've read) will state to you how pointless and useless cross drilled, slotted or both are for any vehicle period....
ACURACY_VTEC
Dec 30, 2006 03:05 PM
7808
Jun 18, 2006 09:51 AM
S2Kricer
11
May 12, 2006 03:01 PM
snatch
Nov 18, 2005 08:19 AM
migs
11
Mar 3, 2004 05:56 AM
