wiring!god i hate wiring!
Old Nov 30, 2007 | 11:02 AM
the_big_dl86's Avatar
Default ls vtec wiring
ok some of u may have read im doing a ls vtec swap into my 1990 crx.well im confused as hell with the wiring.i know i need a jumper to run my ecu.but what do i do with my injector clips and alternator plugs.i dont have the money to have someone do it for me so i need to know what to do.help!so i can finish my build
Modified by the_big_dl86 at 9:24 AM 12/3/2007
Modified by the_big_dl86 at 9:25 AM 12/3/2007
Old Dec 6, 2007 | 11:45 AM
pgpbubble's Avatar
Default Re: ls vtec wiring (the_big_dl86)
Obd0 injector; and alternator plugs are the same as OBD1.
Old Dec 6, 2007 | 12:36 PM
soaringchimp's Avatar
Default Re: ls vtec wiring (pgpbubble)
Your swap should have come with a wiring harness. If it did not i recommend trying to find one. They are fairly easy to swap out and will be a whole lot simpler than trying to run all your own wiring.
Old Dec 6, 2007 | 12:47 PM
likwid2u's Avatar
for the injectors you can use your obd0 injectors on the stock motor as for the alternator you can use the original LS alternator and then you can use the original harness from your car
bigdogadam
May 24, 2007 03:50 PM
PurEvl
11
Feb 21, 2006 11:41 AM
sLoWrAcEr
Mar 2, 2005 05:21 PM
JoshM
Oct 9, 2002 01:27 AM
