Professional products gsr & itr throttle body differece?
Old Nov 30, 2007 | 10:22 AM
ej_b16a's Avatar
Default Professional products gsr & itr throttle body differece?
Would like to know the difference between the professional products gsr & itr throttle body?
What throttle body is best to use on a b16a obd1, gsr or type r?
thanks
Old Nov 30, 2007 | 10:54 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Professional products gsr & itr throttle body differece? (ej_b16a)
Honesty, I own a 68 mm profession products TB and I don't really know if there is difference between gsr and itr.
The TB I have those is pretty good. No sealing issues, no sticking throttle plate, etc.
For a B16a, I would recommend a 62 mm. If you are staying with the P30 manifold then I don't think you can use anything larger than 64mm.
Old Nov 30, 2007 | 11:12 AM
Dyno Dave's Avatar
ITR is the best TB to use if you use the GSR unit the bell crank for the throttle cable will pull the wrong way.
Regards Dyno Dave
Old Nov 30, 2007 | 11:15 AM
all-mtr-teg's Avatar
The main difference is the position where the throttle spring and cable attach, GSR cable attaches the opposite way as ITR. I used a ITR TB and ITR cable on my GSR after i installed my Skunk2 IM.
Old Nov 30, 2007 | 11:19 AM
ej_b16a's Avatar
Default Re: Professional products gsr & itr throttle body differece? (mar778c)
No, don't stay with the p30. I have a edelbrock performer x manifold and want to use the prof.prod. 65 mm tb.
Old Nov 30, 2007 | 11:21 AM
ej_b16a's Avatar
Ok thanks, than I will order the type r tb.
Old Nov 30, 2007 | 11:29 AM
Natural Aspirations's Avatar
The main difference is the GSR TB has a spot for the thing under the throttle body(cold start valve) and the ITR does not. I forget the actual name of it as I have never has one.
Old Nov 30, 2007 | 11:56 AM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej_b16a &raquo;</TD></TR><TR><TD CLASS="quote">No, don't stay with the p30. I have a edelbrock performer x manifold and want to use the prof.prod. 65 mm tb.</TD></TR></TABLE>
Thank is a nice combo.
Old Nov 30, 2007 | 12:27 PM
ej_b16a's Avatar
Default Re: (Natural Aspirations)
ok thank man, you mean the fast idle valve. I don't need it, so the itr tb will be ok.
nelson9994
Sep 2, 2011 10:17 AM
NosShootinHonda
Jan 9, 2009 05:38 AM
xander1100
Aug 21, 2008 01:03 AM
stallionsdc2
Sep 5, 2006 09:20 PM
spankey167
Oct 12, 2004 12:18 AM
