Can you shorten a radiator????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain »</TD></TR><TR><TD CLASS="quote">Is it possible to cut and reweld?</TD></TR></TABLE>
yes.
yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robbbby »</TD></TR><TR><TD CLASS="quote">I have to do the same thing, I need to take about 6" off of mine. Am kind of curious how to do it properly.</TD></TR></TABLE>
x2
x2
Yup, should be doable with most radiators w/metal end tanks. I did this on the one below. I also added in a 2.5" strip along the side to prevent side damage to the newly exposed tubes
I cut mine with my HF bandsaw in the vertical position and it ate right through the fins. I just have to find a good way to remove the remainder of the fins from the now outside tube so I can cover it with a sheet of aluminum.
standbackimapro
25
May 22, 2024 12:35 AM
