vaccum leaks.
i can hear a huge one. ive checked all of them but still no luck. can someone give me advice? its could also be the reason why my engine stumbles when i fully gas it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist »</TD></TR><TR><TD CLASS="quote">That works, but water would be safer. Only difference is idle would drop when the watter plugs the leak.</TD></TR></TABLE>
WTF
? Why would you put water near your intake manifold where there is a leak? Are you retarded? Do you know what happens if water somehow finds its way into the combustion chamber?
Use brake cleaner or carb/choke cleaner and you should be able to find it quick. Just dont use water, thats just plain stupid.
WTF
? Why would you put water near your intake manifold where there is a leak? Are you retarded? Do you know what happens if water somehow finds its way into the combustion chamber?Use brake cleaner or carb/choke cleaner and you should be able to find it quick. Just dont use water, thats just plain stupid.
Stupid is blowing your face off in a flash fire.
A small vacuum leak shouldn't ingest a huge amount of water, and the little bit that may get sucked in is way to insignificant to cause any damage. It's not like you're pouring it into a gaping hole. If there is a gaping hole, it should be obvious and not further troubleshooting would be required.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lokisdope »</TD></TR><TR><TD CLASS="quote">i can hear a huge one. </TD></TR></TABLE>
A small vacuum leak shouldn't ingest a huge amount of water </TD></TR></TABLE>
Even if it was a small leak why risk it?
Tiltboy311
Feb 10, 2011 11:56 AM
wallabee32
Feb 6, 2008 04:18 PM
