what you know about that???...that heat...
Old Nov 30, 2007 | 04:02 AM
VTEC_PRODUCTION's Avatar
Default what you know about that???...that heat...
well im not sure if some of you guys remember my post from awhile back...but it seemed like my car's engine temp was really low, due to the thermostat. well i have not done anything with it because it seemed to be alright since i was getting heat. but now that colder weather has rolled in it seems like my heat isnt as warm as it could be...and it seems like it takes awhile for it to heat up...but it still gets there but not very hot...is this also due to the t-stat improperly functioning?
because on days like these i feel like i need the heat...
yea we got dumped on today. this is just within a couple of hours...i live near Lansing and this should not happen at all in my opinion...
Old Nov 30, 2007 | 04:15 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: what you know about that???...that heat... (VTEC_PRODUCTION)
Most likely. I just picked up a thermostat for my '97 GSR. My tell-tale sign is that the temperature will drop if I coast up to lights while in gear.
Old Nov 30, 2007 | 04:21 AM
Default Re: what you know about that???...that heat... (Dogginator)
same here...good point...
Old Nov 30, 2007 | 04:50 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Most likely. I just picked up a thermostat for my '97 GSR. My tell-tale sign is that the temperature will drop if I coast up to lights while in gear.</TD></TR></TABLE>
Mine was so bad that it would heat up to normal sitting still, and as soon as I moved it would drop down past "C".
Old Nov 30, 2007 | 05:34 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: what you know about that???...that heat... (AWD Terror)
the snow makes your car look like it has super cool aletezza tail lights
Old Nov 30, 2007 | 03:09 PM
PACT man's Avatar
Default Re: what you know about that???...that heat... (GRAF-FITI)
lol, thats when you need remote start to warm up the car and heat. You don't even need to block out the license plate in the pic, snow did it for you.
Old Nov 30, 2007 | 05:24 PM
frankenstienEk's Avatar
Default Re: what you know about that???...that heat... (PACT man)
i feel bad for you motor
Old Nov 30, 2007 | 07:31 PM
Dogginator's Avatar
Daisy... Daisy...
My thermostat is changed. The temperature needle is riding slightly higher than I ever recall. I think that my thermostat was screwed from the start since the car was new. I'll check the warm-up tomorrow.
b01
Honda Civic (2006 - 2015)
Sep 14, 2008 03:17 PM
sony224422
Jan 29, 2007 05:24 PM
ITR632
27
Dec 26, 2005 08:26 PM
TheSSG
Dec 6, 2005 02:00 PM
Buckshot
Sep 20, 2002 08:32 PM
