water cooled ic VS air cooled........
A water cooled setup is very rare on h-t.
I wonder why?
It doesnt have to be expensive...
Its only a little more work...
It will kill some turbo lag...
it is a little heavier.
Does it cool less efficient???
Or does it choke more than an air to air ic???
any thoughts on this?
Would you guys use it on a rear engined car?
anybody got a water cooled setup to show?
thanks!
I wonder why?
thanks!
water to air is superior to air to air, but most of the racers on here are "sfwd" setups and that setup isnt legal. and in t/s all the components needed to be under the hood. no reservoir in the pass compartment.
it works and works well, but on a street setup, unless you pack with ice all the time, it will heat soak sooner or later on a long trip. or have to run another radiator / heat exchanger for the water in the intercooler system.
we went 12.28 in my 87 t type in 96. all we did was go to water to air intercooler and went 11.80.
i was thinking of using an extra radiator and an electric pump.
will this work pretty good or is there only an advantage if you use ice?
I assume it will make a pretty big difference in spoolup time / lag.
thanks!
thanks!
The real reason I'd suspect is the SFWD deal and the fact a FMIC fits much better than any air-water core, not to mention the pump and reservoir/heat exchanger.
The other deal is price. You can make 400whp on a $100 FMIC, so why spend 2-4x as much for a space-eating, complicated solution when you can just get a precision core for less?
the reason for me will be: rear engine street track car and i don't want lag.
+ 375 dollar for a new air to water isnt more expensive then a fmic and a normal radiator isnt very expensive 2
allhonda
Welding / Fabrication
14
Jan 16, 2009 05:07 AM
Wo-Nelly
May 26, 2004 08:53 AM
