So my oil lamp light didnt turn on today
Old Nov 29, 2007 | 11:18 PM
preludedriva's Avatar
Default So my oil lamp light didnt turn on today
you know how your light turns on when you turn the car onto the on position and when you first start the car
well mine doens teven turn on anymore now as of today
any suggestions?
Old Nov 29, 2007 | 11:34 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: So my oil lamp light didnt turn on today (preludedriva)
check oil pressure switch and/or bulb in the cluster
Old Nov 29, 2007 | 11:58 PM
Default Re: So my oil lamp light didnt turn on today (n1_egsex)
vtec oil pressure switch?
Old Nov 30, 2007 | 12:53 AM
Bejita's Avatar
lol.....change the bulb. Start small.
Old Nov 30, 2007 | 01:19 AM
Default Re: (Bejita)
could it be anything else?
Old Nov 30, 2007 | 06:50 AM
EE_Chris's Avatar
Default Re: (preludedriva)
The circuit is simple. It consists of the sensor screwed into your block (and no, not the VTEC oil pressure sensor...just a seperate one dedicated to the little idiot light in your cluster), connected through a piece of wire to the bulb in your cluster. The other side of the bulb connects to a switched +12v source.
Check the light.
Light Bad? Replace light.
Light Good? Check teh sensor.
Sensor Bad? Replace sensor.
Sensor Good? Use a meter to check for shorts/opens in the wire.
Don't have a meter? Replace it all until it works.
Old Nov 30, 2007 | 09:37 PM
MuddinPede's Avatar
Default Re: (EE_Chris)
Electrician?
Old Nov 30, 2007 | 11:44 PM
it fixed it self thanks guyslol
slywfbpsi
May 7, 2011 10:17 AM
singlecamsaint
Sep 30, 2010 11:27 AM
92integraVTECgsr
Jun 7, 2008 02:35 PM
BIGBLOCKEK
Mar 13, 2005 07:21 PM
Cashflo
Oct 25, 2003 09:00 AM
