NEED HELP WITH ENGINE SHUTING DOWN
Old Nov 29, 2007 | 11:01 PM
bwr3476_ky's Avatar
Default NEED HELP WITH ENGINE SHUTING DOWN
i have a 1996 honda civic 1.6 vtec.
now the first trouble is that the speedo is going crazy when you get on it hard the needle jumps all over the place.could there be someething loose?
second trouble is when im getting on it hard and it revs up to about 6000 rpm the computer shuts it down until i let of the gas and then it picks back up..
Old Nov 29, 2007 | 11:05 PM
juscallmetoad's Avatar
Default Re: NEED HELP WITH ENGINE SHUTING DOWN (bwr3476_ky)
maybe some you got some plugs assed backwards. and maybe the vss is jacked up or maybe even the speedometer itself.
Old Nov 29, 2007 | 11:07 PM
bwr3476_ky's Avatar
Default Re: NEED HELP WITH ENGINE SHUTING DOWN (juscallmetoad)
what kind of plugs and what is a vss?
Old Nov 29, 2007 | 11:22 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bwr3476_ky &raquo;</TD></TR><TR><TD CLASS="quote">what kind of plugs and what is a vss? </TD></TR></TABLE>
VSS = Vehicle Speed Sensor.
It tells the ECU how fast you are going, which tells the cluster and cruise control how fast you are going.
If the wiring is faulted (usually this happens when it gets cut and grounds against part of the engine) on the harness going from the VSS to the ECU it makes the VSS have inaccurate/faulty readings which leads to stuff like you mentioned.
epinero
Apr 24, 2018 05:55 PM
mr_loy
Dec 8, 2008 11:04 AM
red-eg6
Jul 24, 2005 08:08 AM
alexngo
19
Mar 23, 2004 04:23 PM
bens96ex
14
Mar 23, 2004 11:45 AM
