del sol
Old Nov 29, 2007 | 08:03 PM
eg6sittingon57cs's Avatar
Default del sol
im tring to find out what year del sol and model comes with b16 and what would the vin say if its from factory so i have research but cant find anything if you have anything negative plz dont post
Old Nov 29, 2007 | 08:36 PM
broketuner-Sol_Si's Avatar
Default Re: del sol (eg6sittingon57cs)
94-97 VTEC models came with b16a(in 94-95 it had the b16a3, in 96-97 it had the b16a2)
(NOTE: the Si's are most opf the time listed as a VTEC model on FS adds due to their engines being the sohc vtec motors d16z6 or d16y8)
forget the vin tag, I want to say EG2 or EG1
Old Nov 29, 2007 | 08:44 PM
Syndacate's Avatar
Default Re: del sol (broketuner-Sol_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-Sol_Si &raquo;</TD></TR><TR><TD CLASS="quote">94-97 VTEC models came with b16a
forget the vin tag, I want to say EG2 or EG1</TD></TR></TABLE>
It's EG2, EG1 was the base model (S).
Remember, it's "VTEC" aka. DOHC VTEC.
Not if it "has VTEC" - because the Si has VTEC, but that's a D16 SOHC VTEC.
OBD-I models had a B16A3 and OBD-II models ('96+) had a B16A2. It lasted from '94-'97.
Old Nov 29, 2007 | 09:50 PM
JDM-Punk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-Sol_Si &raquo;</TD></TR><TR><TD CLASS="quote">94-97 VTEC models came with b16a(in 94-95 it had the b16a3, in 96-97 it had the b16a2)
and you call yourself a dsoc *****
but yea exactly as what these people listed... and be prepared to not find the vtec model sol and if you can find one, they are most likely around the 5-6k area
Old Nov 29, 2007 | 09:56 PM
Syndacate's Avatar
Default Re: del sol (JDM-Punk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-Punk &raquo;</TD></TR><TR><TD CLASS="quote">
but yea exactly as what these people listed... and be prepared to not find the vtec model sol and if you can find one, they are most likely around the 5-6k area</TD></TR></TABLE>
Yeah man, I've SEEN one legit Del Sol "VTEC" in good condition. Seen a few in crappy condition, but that #'s still under 5.
Most of the "VTEC" ones are the Si's with the Z6/Y8 in them.
Though I haven't seen that many sols, PERIOD. So uhh, guess I'm kinda excluded anyways.
Old Nov 29, 2007 | 09:59 PM
highrev1987's Avatar
Default Re: del sol (Syndacate)
ONLY THE DOHC was called VTEC, trust me i have the tech manual for every year
Old Nov 29, 2007 | 10:02 PM
Syndacate's Avatar
Default Re: del sol (highrev1987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 &raquo;</TD></TR><TR><TD CLASS="quote">ONLY THE DOHC was called VTEC, trust me i have the tech manual for every year</TD></TR></TABLE>
Good for you, but a lot of sols are marked as "VTEC" when they're the Si models and do have VTEC, but it's a Z6 or a Y8, as both of us said, so shush.
@ OP: Just look for EG2 as the 4th, 5th, and 6th chars of the VIN.
EDIT:
I'm sorry, all three of us.
Old Nov 29, 2007 | 10:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
EDIT:
I'm sorry, all three of us.</TD></TR></TABLE>
you fail again, no sohc sols were called 'VTEC' and they didnt sport the badge
Old Nov 29, 2007 | 10:23 PM
Syndacate's Avatar
you fail again, no sohc sols were called 'VTEC' and they didnt sport the badge</TD></TR></TABLE>
And you fail at reading again.
Not once did I ever say they were called VTEC by Honda.
A lot of people, when selling them as used cars, market them as "VTEC" due to the fact that they do infact have VTEC, regardless of what Honda ever intended by putting the DOHC B16 in there. If you actually did **** in the real world you wouldn't even post what you did.
Now go take your sol manuals and run along, you're pathetic.
Old Nov 29, 2007 | 10:25 PM
Now go take your sol manuals and run along, you're pathetic.</TD></TR></TABLE>
GO F U C K Y O U R S E L F BENCHRICER
there as maturely as i could
Old Nov 29, 2007 | 10:27 PM
Syndacate's Avatar
there as maturely as i could</TD></TR></TABLE>
Good, now go.
thanks appreciate the help guys
Old Nov 29, 2007 | 10:33 PM
james p.'s Avatar
del Sol "S" - EG1 - D15, D16 &lt; both non VTEC
del Sol "Si" - EH6 - D16Z6, D16Y8 &lt; both single cam VTEC
del Sol "VTEC" - EG2 - B16A3, B16A2 &lt; both dual cam VTEC
Old Nov 29, 2007 | 10:41 PM
Syndacate's Avatar
Default Re: del sol (james p.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by james p. &raquo;</TD></TR><TR><TD CLASS="quote">del Sol "S" - EG1 - D15, D16 &lt; both non VTEC
del Sol "VTEC" - EG2 - B16A3, B16A2 &lt; both dual cam VTEC</TD></TR></TABLE>
On one hand you're 15 posts late, on the other b/c you're a fellow greek I won't make fun of you.
Old Nov 29, 2007 | 10:59 PM
james p.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">On one hand you're 15 posts late, on the other b/c you're a fellow greek I won't make fun of you.</TD></TR></TABLE>
Someone posted the link on the dSoc thread, I thought I'd help out without getting involved with the above posts.
Besides we've got anywhere between 7 to 10 hours time difference, so yeah I'm late.
Xairetismous apo tin Patrida!
Old Nov 29, 2007 | 11:04 PM
why isn't banning people like you easy?
me and syndicate killed this thread in only the 1st 2 posts....if you had any sort of REED-ING KOMP-REE-HEN-SHUN (tried to sound it out so you get the grasp ) you would've understood what both syndicate and I were explaining which is simply:
when a person tries to sell an sohc vtec del sol (following me still?)
they tend to mark it as a VTEC model so they get more looks because the true VTEC model sol is so rare
(get it? got it? GOOD!....now go drink a gallon of bleach or try and find a natural gas leak with a lighter or something of the suicidal nature)
Old Nov 29, 2007 | 11:29 PM
EG2_KING's Avatar
LMAO well said
Old Nov 30, 2007 | 07:43 AM
JtriX21's Avatar
yeah, you're a little late but i want to clarify on this info.
USDM
1993-1995
del Sol "S" - EG1 - D15B7 non VTEC
del Sol "Si" - EH6 - D16Z6 single cam VTEC
del Sol "VTEC" - EG2 - B16A3 dual cam VTEC
1996-1997
del Sol "S" - EH6 - D16Y7 non VTEC
del Sol "Si" - EH6 - D16Y8 single cam VTEC
del Sol "VTEC" - EG2 - B16A2 dual cam VTEC
So basically the 96-97 S is an eh6 as well.
89 pos
11
Dec 6, 2004 07:25 PM
1MeaNDeLsOL
Jul 24, 2003 06:10 PM
816d16
16
Feb 19, 2003 08:19 PM
Turtle
Jan 29, 2003 08:32 PM
Sterling
12
Jul 17, 2002 06:12 AM
