Toda cams??? Stock valvetrain??
Can you put toda cams in a stock typer with out anthing else except maybe cam gears. i know you wont get alot of power that you could with more but for now until I can afford the rest can you put them in a stock car and have reliability???
Maybe with A's youll have reliability. B's or C's not so much, and they wont make any power with the stock ECU since it wont allow them to rev high enough to get into the meet of those cams powerbands.
I think as long as you keep the stock rev limit, then it is OK. But I wouldn't run it for a extended period of time!!
You can run Spec A's and camgears while leaving everythng else stock INCLUDING the redline. You won't get much power if you don't tune though, you could actually lose power.
Nothing wrong with running stock ECU and Spec B, what I meant is that I wouldn't run stock valvetrain with spec B for extended period of time!!
You probably shouldn't do that at all!!
He'll be fine running Spec B's with stock valvetrain as long as he's not going over 9100 rpm or so. Even then I wouldn't want to run up to 9000 all that often on stock valvetrain.
Please be careful with the sensationalism.
Toda recommends springs and retainers....
And if one owns the money to get a set of cams he`s got the bucks for valvetrain also...
I would never risk the stock valvetrain and get the head fawked up
For Toda A's like I have, you don't need valvetrain. Very reliable and I am making a lot off power specially low end. You just have to tune the car.
Yes.
1 year, 7k miles on Toda B's, cam gears, V-AFC, stock valvetrain, JDM 4-1, 2.5" cat, stock b-pipe + can.
Did I make more power than stock? Yes. 18-20whp delta in midrange.
Did I make the most power? No. Peak numbers are for pansies.
Stay out of the rev limiter, and you will be fine. Put the cams in now, add the goodies later, if you are budget-minded like me.
Dont waste your money the Toda Valvetrain is identical to Type R outers and Portflow inners half the price, The only Toda cam worth running is the A's the C'S are JUNK.
Drinker
