Anyone Gas Guage Is stuck at FULL?
Old Nov 29, 2007 | 05:14 PM
bossman032's Avatar
Default Anyone Gas Guage Is stuck at FULL?
I have a 89 si, my gas guage is stuck at FULL all the time!
Anybody know what can be wrong I am thinking it might be the cluster but anyways my cluster has 320,000 miles on it. I am thinking it might the resistor is bad?
any clues guys ?
Old Nov 29, 2007 | 05:19 PM
Ermil's Avatar
Default Re: Anyone Gas Guage Is stuck at FULL? (bossman032)
Sounds like a broken and/or grounded out wire. Did you test the sender? Power at the sender?
Old Nov 29, 2007 | 05:39 PM
CRX Toad's Avatar
Default Re: Anyone Gas Guage Is stuck at FULL? (Ermil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a broken and/or grounded out wire. Did you test the sender? Power at the sender?</TD></TR></TABLE>
And test the gauge
bossman032's Avatar
ground wire out?
there is no ground wire at the pump?
I didn't test for power but what I think I should do is do a continunity test from the sender to the cluster..
Old Nov 29, 2007 | 06:45 PM
Crx Jimmy's Avatar
I had this problem it wasnt the sender so I replaced the gauge in the dash I think it was like $27 at honda for the whole thing with the temp gauge attached as well
Old Nov 29, 2007 | 07:10 PM
bossman032's Avatar
Default Re: Anyone Gas Guage Is stuck at FULL? (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I had this problem it wasnt the sender so I replaced the gauge in the dash I think it was like $27 at honda for the whole thing with the temp gauge attached as well</TD></TR></TABLE>
your talking about the circuit in the back of the cluster?
http://www.hondaautomotivepart...ND%29
Old Nov 29, 2007 | 07:49 PM
michael O's Avatar
I had this problem too. I just picked up another gauge from pick n pull for free.
Old Nov 29, 2007 | 07:52 PM
bossman032's Avatar
Default Re: Anyone Gas Guage Is stuck at FULL? (michael O)
what exactly goes bad the resistor?
Old Nov 30, 2007 | 06:30 AM
~sp33~'s Avatar
EFB055
Wish my gas tank stayed full! :D
Old Nov 30, 2007 | 07:47 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">what exactly goes bad the resistor? </TD></TR></TABLE>
The resistor is what controls the signal from the injectors. So if it went bad the injectors would stop working. But it doesn't go bad, it's not a common issue.
Replace your cluster, easiest thing.
Old Nov 30, 2007 | 09:45 AM
bossman032's Avatar
Default Re: Anyone Gas Guage Is stuck at FULL? (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
Replace your cluster, easiest thing.</TD></TR></TABLE>
ohh I thought the cluster had some kinda resistor for the ohms in the back of the circuit...
Old Nov 30, 2007 | 04:22 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The resistor in this case is considered the "sending unit.."
It is a varible resistor with a float attached..
Here are the test pages from the manual:
Old Nov 30, 2007 | 04:41 PM
Mr Synister's Avatar
Default Re: Anyone Gas Guage Is stuck at FULL? (88DXCRX)
well on a kinda same topic my gas gauge never goes up to full. it reads just fine but it doesnt go all the way up even with a FULL tank of gas. any ideas ? oh yea its a 00 si cluster
Old Nov 30, 2007 | 08:14 PM
bossman032's Avatar
Default Re: Anyone Gas Guage Is stuck at FULL? (Mr Synister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Synister &raquo;</TD></TR><TR><TD CLASS="quote">well on a kinda same topic my gas gauge never goes up to full. it reads just fine but it doesnt go all the way up even with a FULL tank of gas. any ideas ? oh yea its a 00 si cluster</TD></TR></TABLE>
get your own thread noob!
might be ur car is too slow for the cluster?
Old Nov 30, 2007 | 11:42 PM
ef yu's Avatar
i too have this problem...sucks...its been like that for half a year..try these, swap out cluster,unplug fuel sender unit(see if your gas guage meter goes down),volt meter, and swap out the sender unit.
Old Dec 1, 2007 | 09:00 AM
bossman032's Avatar
Default Re: Anyone Gas Guage Is stuck at FULL? (ef yu)
where can I buy the sender unit? any ideas how much does that **** cost?
Old Dec 1, 2007 | 01:04 PM
ef yu's Avatar
test out the unit before you assume the sender unit is faulty. buy a volt meter from your local auto parts store.
Old Dec 1, 2007 | 02:03 PM
ef yu's Avatar
YEA lol i just fixed mine hahaha
i just swaped out the cluster lol ...i change the cluster b4, guess the ones i had were all faulty lol. check your cluster
NOW i can cruise all i want without the worry of no more gas yee
Old Dec 1, 2007 | 05:18 PM
bossman032's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef yu &raquo;</TD></TR><TR><TD CLASS="quote">YEA lol i just fixed mine hahaha
NOW i can cruise all i want without the worry of no more gas yee</TD></TR></TABLE>
haha. I thought it was the cluster I will try to find another cluster soon.
Old Feb 4, 2008 | 01:07 PM
bossman032's Avatar
problem fixed, it was the cluster! expletiveen 3 years of driving guessing how much gas I had left and now its fixed.
only got stranded a few times.
BasedDean
Feb 18, 2014 06:52 PM
DeeJaaY209
Sep 19, 2013 01:27 AM
Epidemic06
May 9, 2009 10:22 PM
deerman2701
Audio / Security / Video
11
Dec 10, 2008 02:12 PM
shivic
Aug 2, 2005 05:03 PM
