compression on an hf?
Test the cylinders with all the sparkplugs out, using the same number of cranks for each cylinder (4-6), and make sure the throttle is wide open while you do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">at 250rpm, wide open throttle
nominal - 185 psi
minimum - 135 psi
max. variation - 28 psi</TD></TR></TABLE>
250 RPM?
nominal - 185 psi
minimum - 135 psi
250 RPM?
damn it! well the whole problem was, the car was bought and RUNNING! i decided to take the head off to replace all internal seals. i put it all back together and now it wont START! wow!..anways. cylinder #1 120 #2 150 #3 135 #4 ZERO! oh no!what should i do?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">
250 RPM? </TD></TR></TABLE>that is what the manual says
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fuzzy Rhubarb »</TD></TR><TR><TD CLASS="quote">or messed up valve seals</TD></TR></TABLE>
How would a valve seal effect compression?
did the car over heat or something why did u pull the head....... maybe you burnt a valve or cracked a ring or something my turbo zc had 195-1 190-2 195-3 and 0-4 i burnt a valve so id pull the head back off and relap the valves or check your piston rings out....
could his compression be way low if the timing is really far off.....
i doubt anything is wrong with the bottom block. damn exhaust valves had a crapload of carbon build up. it never overheated. i guess i have to just pick up a head from my yard.
The valves seal against the combustion chamber will, but not the valve seal.
Lol, kinda hard to explain. The valve's seal will effect compression, but not the valve seal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">Lol, kinda hard to explain. The valve's seal will effect compression, but not the valve seal.</TD></TR></TABLE>
I know exactly what you mean. I don't know why I thought that. If the valve fully closed against the head, it doesn't matter about the valve seal. The compressed air would never reach it. duh
if it did have something to do with the exhaust valve, would replacing it with a new one solve it? also, what other model ef cylinder head can i swap out for stock features?
well, it's now down to buying a used head that was running OR replacing the exhaust valves with new ones( if thats all it takes to seal it. )
