cv axle HELP...........
Old Nov 29, 2007 | 03:50 PM
mark2583's Avatar
Default cv axle HELP...........
is there a trick to getting the wheel assembly off of the LBJ because i have everything loose and i cant get it out even w help from a friend. Hopefully there is something else i can do before giving up and bringing it to a shop (driver side axle)
Old Nov 29, 2007 | 04:23 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: cv axle HELP........... (mark2583)
prybars and you pull down while your friend is applying pressure hope this helps
Old Nov 29, 2007 | 04:55 PM
The-Kid's Avatar
Default Re: cv axle HELP........... (I got the CD5 Jeebies!)
Ball joint seperator. From autozone. Not the fork type. Or you can hit the side of the nut with a hammer. I've seen that work.
Old Nov 29, 2007 | 04:59 PM
mark2583's Avatar
Default Re: cv axle HELP........... (The-Kid)
ball joint separator sounds good, i'll try it
Old Nov 29, 2007 | 05:18 PM
The-Kid's Avatar
http://www.mytoolstore.com/astro/7838.jpg it looks like the middle one. the the 2 fingers go on the lower control arm and the screw in the middle goes on the ball joint. Hook it up to a rachet and rachet away. It might make a LOUD!!!!!!!!!!!! pop. well mine was sticky.
Old Nov 30, 2007 | 07:46 PM
PnX-R's Avatar
I'm assuming that you mean you're trying to separate the lower ball joint from the knuckle.. What I usually do is hit it with a big 3lbs hammer/sledge. I usually have the car in the air though. But I have had to do it on the floor too. I find it best if I turn the wheel all the way to one side and get a clear shot at it. I usually try to swing the hammer horizontally by resting the hammer on the ground swinging up towards the ball joint. Just remember to put the nut back on the ball joint after you've loosened it. It'll prevent you from damaging the threads with your hammer. A few good hits should pop that free.
lowtegsr
Mar 6, 2008 12:49 PM
si 1
10
Dec 29, 2005 03:32 AM
VisualAutoMotoring
Oct 11, 2003 04:08 PM
GruvyTune
Jul 22, 2002 10:01 AM
kilabeez
Sep 18, 2001 06:58 AM
