oil in coolant?
Old Nov 29, 2007 | 02:26 PM
Team 4's Avatar
Default oil in coolant?
what causes oil to end up in the coolant system?
Old Nov 29, 2007 | 02:27 PM
T-Mo's Avatar
a blown head gasket
Old Nov 29, 2007 | 02:29 PM
Team 4's Avatar
Default Re: (T-Mo)
any more cuases? please need to know al the possible things it could be so we can asess it
Old Nov 29, 2007 | 02:31 PM
SoTexDC2's Avatar
Cracked/Blown head gasket, Or could also be a cracked sleeve or block.
Old Nov 29, 2007 | 02:32 PM
Team 4's Avatar
Default Re: (SoTexDC2)
its a stock gsr 98..ish with an intake.. what is the probability oft hat happening?
Old Nov 29, 2007 | 02:33 PM
AWD Terror's Avatar
Default Re: (Team 4)
HG
Broken sleeves inside the block.
You are gonna hope it is a HG.
Anything done to your motor?
Old Nov 29, 2007 | 02:34 PM
Team 4's Avatar
Default Re: (AWD Terror)
not mine all stock just aem v2 intake
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team 4 &raquo;</TD></TR><TR><TD CLASS="quote">its a stock gsr 98..ish with an intake.. what is the probability oft hat happening?</TD></TR></TABLE>
HG
Edit: Miles?
Old Nov 29, 2007 | 02:35 PM
SoTexDC2's Avatar
With a N/A stock engine, its more than likely the head gasket. A compression and Leakdown check will tell you for sure.
Old Nov 29, 2007 | 02:36 PM
Team 4's Avatar
going to try leakdown.. thanks for the help guys thred over!
Old Nov 29, 2007 | 02:44 PM
asr10 user's Avatar
Blown HG. Sell the car while your ahead.
AWD Terror's Avatar
Let us know how it goes.
If you need to buy a HG, make sure you get a OEM honda one.
If you are even thinking about doing any kind of a build, I would put ARP head studs in, and crank them down more than the stock specs. Might as well do it while you have the head off.
GL
Old Nov 29, 2007 | 02:46 PM
AWD Terror's Avatar
Default Re: (asr10 user)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asr10 user &raquo;</TD></TR><TR><TD CLASS="quote">Blown HG. Sell the car while your ahead.</TD></TR></TABLE>
STFU n00b.
A HG is a weekend job. A full day if you have done one before.
Old Nov 29, 2007 | 03:44 PM
SoTexDC2's Avatar
If the mileage is getting high, replace the HG, Timing Belt, Tensioner, Water Pump, Front cam seals, and continue to enjoy the car.
Old Jan 30, 2008 | 06:50 AM
91redteg's Avatar
if it was a broken sleeve it would be putting a significant amount of oil in the coolant tho wouldnt it
Old Jan 30, 2008 | 06:53 AM
crazyguy's Avatar
Default Re: oil in coolant? (Team 4)
time to change head gasket
Old Feb 2, 2008 | 11:39 PM
GSTDA9's Avatar
BHG!!!!!!
AHHHH!!!!!
Old Feb 3, 2008 | 01:27 AM
jhammond_82's Avatar
Reject Papi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">A HG is a weekend job. A full day if you have done one before.</TD></TR></TABLE> agreed. it shouldn't be that difficult of a job, just make sure you get a helms, or haynes book to walk you through the process. take your time, and do it right the first time and you shouldn't have to do it again for a longgg time. awd, where the expletive have you been? haven't seen you for a while.
Old Feb 3, 2008 | 02:35 AM
yc_dc4mar's Avatar
i hope you were joking bec your a retard for thinking the car is done. i put a hole in a valve and blew a head gasket and thermostate. got it all fixed in 2 days time with some help.
Old Feb 3, 2008 | 09:53 AM
FLA-DC2's Avatar
Blown HG
Old Feb 3, 2008 | 12:41 PM
mrrex1990's Avatar
its a bad head gasket not cheap either
Old Feb 8, 2008 | 11:47 PM
GSTDA9's Avatar
Default Re: oil in coolant? (mrrex1990)
hg is only like $40
Old Mar 9, 2008 | 10:17 PM
s0uk's Avatar
i just helped my friend put an engine together, it sounds like you had the same situation we went through, we went through 3 head gaskets, had the head resurfaced and got new dowels for the head. instead of hooking everything back up and before putting the cams and stuff back on, just bolt the head down, connect all your hose and run water through the radiator and pump it, wait like 2-5 min for it all to flow through, if you didn't connect your oil line, you should see water coming out of it, if you do something wasn't plugged up in there. my buddy took his head to get cleaned and he had to change his valves on piston #1 since it was messed up but we eventually had to use a diff head. that's how the oil got into the radiator and how it got to the whole block, head, and oil pan. unbolt your oil pan bolt to see if water runs through that too. i'm not sure if this helps but that's what we did to trouble shoot the problem...
he got his head pressure checked and all that good stuff too. we finally figured where it was leaking after 2 weeks of trouble shooting...
Modified by s0uk at 11:33 PM 3/9/2008
Old Mar 10, 2008 | 02:41 AM
OC Geezer's Avatar
Default Re: oil in coolant? (s0uk)
99% of the time when you have oil in the coolant it's the result of a blown headgasket. Check that out first, because that WILL be the problem, rarely if that isn't the case then you are unlucky and need to check the sleeves.
So in this case Busted HG FTW!
Old Mar 10, 2008 | 04:52 PM
BoSox46GSr's Avatar
Default Re: oil in coolant? (OC Geezer)
Sounds like a headgasket! Has that already been said?
