99 accord gauges not lighting up.
I was told that there was a recall on the multiplex control unit but when i went to the dealership, the recall wasn't in their system. IAM NAS, if you are looking at the fuse box on the driver side, the second fuse on the right row is the one you should change. it should be a 7.5a fuse. So back to my problem, is there anything anyone could come up with that could be causing the problem?
i am currently having the same problem on a 98 accord v6 coupe, swapped gauge clusters andeverything, and nothing, ive been trying to find a diagnostic chart to figure out the problem and nothing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ckinne »</TD></TR><TR><TD CLASS="quote">So back to my problem, is there anything anyone could come up with that could be causing the problem?</TD></TR></TABLE> drivers side multiplex
could it be a relay? I have been trying to diagnose a problem with my 93 civic that is similar... when I turn the headlights on it takes a while for my interior and running lights to come on. of course they are probably different problems, but I am curious to hear of what fixes it for you.
good luck
good luck
