To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup
Old Nov 29, 2007 | 10:36 AM
rev-speed's Avatar
Default To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup
It all started as a quest to make 220 whp on a 1.8l
about a year and a half ago i make 208whp on a 1.8L
setup
head
gsr
supertech valve springs and retainers
jun II cams
jg intake manifold
jg cam gears
jg throttle body 68mm
block
integra ls
ctr pistons 81mm
ls rods
arp rod bolts
gsr block griddle
gsr main center caps
fuel managment
crome
rc 320cc
255lph walbro fuel pump
tranny
b16
all stock
header
dtr
4-2-1
now i have a
setup
head
b16 dtr ported
port flow valve springs and retainers
sk2 stg3 cams
jg intake manifold
jg cam gears
block
integra ls
ctr pistons 81mm
ls rods
arp rod bolts
gsr block griddle
fuel managment
hondata s200
rc 750cc
90si fuel pump
dtm headers
Boy do i have the luck......
first time to dyno no vtec
found the problem to be too small of v tec oil line
second time to dyno
valves kiss piston on first vtec pass
went back to the shop
found belt is now a teeth off
line up the belt and did compression
what the fu-k only 180psi
o-well
i still went back and dyno
made a 209whp pass still need to finish tuning dyno comp was locking up
setup
208whp 1.5 year ago
[IMG] http://imgcash2.imageshack.us/...1.jpg [/IMG]
209whp on a hurt motor now with the missing link..........
here s the results
dtm headers 166.9whp (what can i say its a hurt motor)
dtm headers (with the missing link everyone needs) 209.1whp 144ft tq
Modified by rev-speed at 7:38 PM 11/29/2007
Old Nov 29, 2007 | 12:36 PM
Natural Aspirations's Avatar
worst thread ever
Old Nov 29, 2007 | 12:54 PM
hybrid2007's Avatar
Old Nov 29, 2007 | 01:03 PM
dinko's Avatar
Default Re: (hybrid2007)
uhhh...
WHAT!?
Old Nov 29, 2007 | 01:09 PM
sikcivic95's Avatar
Default Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (rev-speed)
there was no point in this thread.. someone delete this.. there is no effing secret.. lol
Old Nov 29, 2007 | 01:21 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed &raquo;</TD></TR><TR><TD CLASS="quote">To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup</TD></TR></TABLE>
Now I can sleep tonight
Old Nov 29, 2007 | 01:32 PM
b20beast978's Avatar
very pointless thread!
Old Nov 29, 2007 | 01:43 PM
turboZChatch's Avatar
Default Re: (b20beast978)
I thought it was goin to be one of those plastic supercharger things for your intake (tornado) hahahaha
Old Nov 29, 2007 | 01:49 PM
rev-speed's Avatar
Default Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
Now I can sleep tonight </TD></TR></TABLE>
b19coupe u disipoint me
u got some good dyno s # s and reply with knowleged
how is it u don t see the gain?
Old Nov 29, 2007 | 01:52 PM
rev-speed's Avatar
Default Re: (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">worst thread ever</TD></TR></TABLE>
it is the worst thread ever when ur ignorant
Old Nov 29, 2007 | 01:53 PM
DonF's Avatar
Default Re: (turboZChatch)
Probably hydro-locked it with those 750cc injectors and 95 psi fuel. Thats why it jumped time. Do most people still go to the dyno after they have bent there valves, just curious.
Old Nov 29, 2007 | 01:58 PM
sittin on GOLD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboZChatch &raquo;</TD></TR><TR><TD CLASS="quote">I thought it was goin to be one of those plastic supercharger things for your intake (tornado) hahahaha </TD></TR></TABLE>
lol
"supercharge any honda" for like 10 bucks...lol
Old Nov 29, 2007 | 02:02 PM
rev-speed's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Probably hydro-locked it with those 750cc injectors and 95 psi fuel. Thats why it jumped time. Do most people still go to the dyno after they have bent there valves, just curious.</TD></TR></TABLE>
no don
i do know how to tune
by the way thanks for the tip on rod end clearance
remeber this thread
what r we missing trying to make 220 whp on a 1.8L?
https://honda-tech.com/zerothread?id=2028103
Old Nov 29, 2007 | 02:10 PM
Default Re: (rev-speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed &raquo;</TD></TR><TR><TD CLASS="quote">what r we missing trying to make 220 whp on a 1.8L?</TD></TR></TABLE>
My motor
Modified by Natural Aspirations at 6:21 PM 11/29/2007
Old Nov 29, 2007 | 02:12 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed &raquo;</TD></TR><TR><TD CLASS="quote">how is it u don t see the gain? </TD></TR></TABLE>
Difficult to read the charts and the differences between dyno runs is not clearly spelled out.
For instance:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B19coupe &raquo;</TD></TR><TR><TD CLASS="quote">The red run is with a full exhaust, the yellow run is open header with minor fuel tuning.
The huge dip at 6,500 and subsequent low power output above 6,500 (on the red run)is due to a huge exhaust restriction.</TD></TR></TABLE>
The gains/losses on the chart are clearly explained and easy to understand.
Old Nov 29, 2007 | 02:38 PM
h22crxpwr's Avatar
so the secret to making an extra 30% is to bend your valves and use a missing link?
Old Nov 29, 2007 | 06:28 PM
sa90eg's Avatar
Default Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (h22crxpwr)
could it be 750cc = meth
Old Nov 29, 2007 | 07:15 PM
MikeySpec's Avatar
Default Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (sa90eg)
tell us more
Old Nov 29, 2007 | 07:26 PM
VtecKiDD's Avatar
Default Re: (DonF)
Old Nov 29, 2007 | 07:48 PM
Mike@K-Tuned's Avatar
So is the OP going to share something...or make us all guess.
Old Nov 29, 2007 | 08:23 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sa90eg &raquo;</TD></TR><TR><TD CLASS="quote">could it be 750cc = meth
Crystal meth maybe
Old Nov 29, 2007 | 09:24 PM
LumpyTheGrumpyCamshaft's Avatar
Default Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (rochesterrice
doubt the op will share his drugs.. don't post when stoned bro..
(puff puff pass tho)
Old Nov 29, 2007 | 10:48 PM
sa90eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LumpyTheGrumpyCamshaft &raquo;</TD></TR><TR><TD CLASS="quote">doubt the op will share his drugs.. don't post when stoned bro..
(puff puff pass tho)</TD></TR></TABLE>
LOL
Old Nov 30, 2007 | 06:52 AM
EGunit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">
Crystal meth maybe </TD></TR></TABLE>
DAMN!!! you beat me to it
and everyone remember....to gain 30% hp....you MUST bend valves
Old Nov 30, 2007 | 07:25 AM
civicxpress's Avatar
that totally sucked whats the secret
