Any idea on the cost to repair this CRAP job or what to do?
i got this si without knowing the damage under the intake box here are some pics,my question is what should i do get it reweilded or?how much approx. would this cost to repair, im unsure what to do,this is such an eyesore and im not sure how wellthis will hold i dont want to get into an accident and have any one or me in my car get killed because of the crappy weilding job
all the damage is before the mounts/tower. and aslong as the affected areas stay attached to the car in an accident, than theyve served there purpose.
Those parts are mostly the area for the car to crush, id be more worried about the cosmetic aspect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">all the damage is before the mounts/tower. and aslong as the affected areas stay attached to the car in an accident, than theyve served there purpose.
Those parts are mostly the area for the car to crush, id be more worried about the cosmetic aspect.</TD></TR></TABLE>
That couldnt be more far from true. The guy obviously states he is worried about safety. Look at that? The welds are horrible, some look too cold, the ones on the rail are too wide, and the plug welds are shitty at best. None of those welds would come close to passing any I-car requirements. With this kind of work, and especially since it appears the person sectioned that front frame rail. Crumple zones are put into a car for a reason, if that joint rusts the hell out (which it will since the outside wasnt protected...i can only imagine what the inside looks like) the car will not crush as intended.
If it was my car, no way it would stay like that.
ur right about the frame rail, but besides that, it isnt that bad.
Im sure there are more welds than whats shown, and aslong as there are itll be fine.That frame rail is however, not structral but def. critical in the cars safety.
so what do you guys think my options are exactly, im unsure of what to do get estimate on costs to fix it,shave it down some repaint it? im just a college student so funds are a little low
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BJA86 »</TD></TR><TR><TD CLASS="quote">so what do you guys think my options are exactly, im unsure of what to do get estimate on costs to fix it,shave it down some repaint it? im just a college student so funds are a little low</TD></TR></TABLE>
if you can't do the repair yourself its not worth it, how much do you want for the car?
ill buy it from you im also in socal.
what motor is in it.........im thinking in the couple of hundred dollar area, i can use another car right now and i can definitly fix those welds LOL dont worry im not going to crush it LOL
The weld are crappy yes, the rust is bad also but i wouldn't go to have it redone anywhere. It just isn't worth it, the differences in the way it crushes will be very minute it won't matter. just grind it out and spray the anticorrosive stuff on it.
kinda like a cavity just get a filling.
Step one is to find out if everything is straight. If it is all lined up right (the spacial relationships are correct) then getting in there and re-welding it is just not that big of a deal.
I generally agree with the posts that it is primarily cosmetic (impossible to be 100% sure without seeing it in person). Most of that could just be cleaned up and painted over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top Ramen »</TD></TR><TR><TD CLASS="quote">Step one is to find out if everything is straight. If it is all lined up right (the spacial relationships are correct) then getting in there and re-welding it is just not that big of a deal.
take it to a reputable body shop and have them check it out. have them put it on the frame machine and make sure its all straight, if its not, have them fix it.
id get that **** fixed. i had a similar situation with my car and first thing i did before anything was take it to the body shop and have them make sure it was straight and safe to begin with.
I generally agree with the posts that it is primarily cosmetic (impossible to be 100% sure without seeing it in person). Most of that could just be cleaned up and painted over.</TD></TR></TABLE>
and thats solid info.
So i think the smartest things to do is make sure everything that needs to be straight is straight, and MAYBE have just the frame rail re-welded (maybe from the guy that wants to buy the car a couple posts up
) and then sand and paint affected areas.
Dont forget, its just a honda civic, so dont go nuts trying to make the thing perfect, b/c its just not worth it.
) and then sand and paint affected areas.Dont forget, its just a honda civic, so dont go nuts trying to make the thing perfect, b/c its just not worth it.
thnx for all the info guys i really rather not sell the car ive only had it for about 7 months engine has low miles and everything else works well its just that damn weilding problem.
ill probably get it checked out like u guys said and see what happens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xci_ed6 »</TD></TR><TR><TD CLASS="quote">the damage should have been reported on the title. if it was not the previous owner may be liable for the repair.</TD></TR></TABLE>
this problem shouldnt have to go that far, it should have been thoroughly inspected before it was purchased.
Any shop that looks at that is going to tell u that its unsafe and is gonna cost too much money to fix, and anyone coming to buy it is going to walk away from it, so just fix the things that need to be fixed and enojoy the car.
